,Convertible top adjustment on E body #1641387
07/02/14 11:51 PM
07/02/14 11:51 PM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
Is anybody here familiar with adjustments on the E body top? When the top is down, the windows all roll up nice and straight. When the top is up, it pushes the driver side quarter window forward about 1/2" at the top, causing the driver door window to overlap it at the top. Have to be very careful closing the door so not to shatter the window. Yes I have the factory service manual, but it doesn't seem to have any adjustment for this. Car has had this issue since I have owned it. I have the interior out right now, so this seemed to be a good time to get to everything. Thanks-
Re: ,Convertible top adjustment on E body [Re: Carsavior] #1641388
07/02/14 11:57 PM
07/02/14 11:57 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
If the passenger side glass is fine and the convertible top header meets up with the windshield frame fine then........
I would try adjusting the drivers side door and qtr glass before I would adjust the top.
Does the top header pegs fit nicely in the top recesses of the windshield frame?
Also, the weather stripping on the top frame has a slit for the qtr window. Is the window entering the slit?
Re: ,Convertible top adjustment on E body [Re: Finoke] #1641389
07/03/14 12:07 AM
07/03/14 12:07 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Re: ,Convertible top adjustment on E body [Re: Finoke] #1641390
07/03/14 12:09 AM
07/03/14 12:09 AM
Monroe, LA USA
Monroe, LA USA
Yes top fits into header good. Pass side is good. Just driver side acting up- that's what has me stumped. Windows line up perfectly with the top down. You can tell the top is pushing the quarter window forward.
Re: ,Convertible top adjustment on E body [Re: Carsavior] #1641391
07/03/14 12:10 AM
07/03/14 12:10 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
The windows can be adjusted fore and aft. It's easy with the interior panels out. I just did it on my vert for the same reason. No problems now.
Re: ,Convertible top adjustment on E body [Re: Finoke] #1641392
07/03/14 12:14 AM
07/03/14 12:14 AM
Monroe, LA USA
Monroe, LA USA
OK I may have to move both of the windows forward to clear the top- that sounds logical. Will check that out tomorrow. Thanks!
Re: ,Convertible top adjustment on E body [Re: Carsavior] #1641393
07/03/14 10:35 AM
07/03/14 10:35 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Let me know how you make out.
