Cometic head gasket question
#1641353
07/02/14 08:53 PM
07/02/14 08:53 PM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Does anyone know the actual bore size on a 4.500" , .040" head gasket? The best I can find is cc volume and computing it backwards it comes out exactly 4.500" Seems that may be a little tight with production variances of castings. I figured I would look for a shelf gasket before ordering a custom size. I have an overbore on this block and really can't believe this is all they make as a stocking part. Thanks, Beep
Oops, gasket number cgt-c5464-040
Re: Cometic head gasket question
[Re: Al_Alguire]
#1641358
07/03/14 12:45 PM
07/03/14 12:45 PM
Posts: 16,928 NC
440Jim
NC
Cometic will make it any way you want it. So 4.530 is a safe bet. I have 4.530 and 4.560 here. Both were custom made as we added some steam holes as well.
I agree, and any Cometic dealer can get them for you. Keith Black racing engines stocks MLS gaskets for 4.500 bore blocks and I believe they are 4.560. Give them a call, the last I heard they were $76.50 each.
[Re: Bigbeep]
#1641359
07/03/14 08:54 PM
07/03/14 08:54 PM
Posts: 1,770 Pa
Wv68charger
Pa
Chomping at the bit is an understatement, but we understand that these things take time to be done the right way so it's all good! Sounds and looks like your going to have a stout combo when it's all said and done Looking forward to seeing how it turns out.
