How to flare aluminum AC lines? #1640731
07/01/14 05:35 PM
07/01/14 05:35 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Anyone know how to put the correct flare on an aluminum AC refrigerant line? Does it require a special tool?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: How to flare aluminum AC lines? [Re: MadMatt] #1640732
07/01/14 08:05 PM
07/01/14 08:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They really aren't flared.
Don't be the exception.
Re: How to flare aluminum AC lines? [Re: Supercuda] #1640733
07/01/14 08:13 PM
07/01/14 08:13 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Then what would the correct term be for the type of end they have?
Re: How to flare aluminum AC lines? [Re: MadMatt] #1640734
07/01/14 08:28 PM
07/01/14 08:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.tubebeadingtool.com/
That's where the O ring seats, I was thinking where the hose makes too the tube and is crimped.
Re: How to flare aluminum AC lines? [Re: MadMatt] #1640735
07/01/14 08:41 PM
07/01/14 08:41 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Which line(s) are you thinking of? A buddy of mine fabricated a couple lines coming off of the dryer. He used two lines spliced / soldered them together making one with the correct flare ends. Perhaps you can do something similar depending on the line.
Re: How to flare aluminum AC lines? [Re: MadMatt] #1640736
07/01/14 08:55 PM
07/01/14 08:55 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I tak my lines to the local radiatior shop. They machine flare all my tubing. I hate leaks.....
Re: How to flare aluminum AC lines? [Re: MadMatt] #1640737
07/01/14 11:10 PM
07/01/14 11:10 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Actually, let me ask another question. I was thinking of doing all my lines in hard line, but a friend of mine says I should go with hose because it has better insulating qualities. Any thoughts from anyone?
Re: How to flare aluminum AC lines? [Re: MadMatt] #1640738
07/02/14 12:50 AM
07/02/14 12:50 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The hose is there to allow for movement of the engine, not for insulating. If you try to replace the hose with hard line you are liable to crack the hard line somewhere.
Re: How to flare aluminum AC lines? [Re: MadMatt] #1640739
07/02/14 01:19 AM
07/02/14 01:19 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I'd stick with the hardline throughout and hose to/from engine, just like factory did. Less likely to develop leaks and easier to find them if they do develop. If OP is concerned about heat infiltration on condensor outlet (where is passes through engine compartment) to evaporator, or on return line to compressor, you can always insulate the hardlines with slightly larger diameter hose of some sort. But most factories didn't, I'm guessing. Three cars here from different manufacturers (Dodge, Acura, Toyota) don't have those hardlines insulated.
Re: How to flare aluminum AC lines? [Re: MadMatt] #1640740
07/02/14 08:54 AM
07/02/14 08:54 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Matt, I had the exact same problem when doing final assembly on my challenger. I preferred the look of the hard line over the rubber hose where possible. As far as functionality, the rubber hose works just as well. To answer your question, yes you can put that type flare on aluminum a/c line using the proper tool. I suggest you rent or borrow one from your local HVAC repair shop, one similar to this: http://www.matcotools.com/catalog/product/AC71475/UNIVERSAL-HYDRAULIC-FLARING-TOOL-KIT/
A simpler way is to try to arrange your line placement to match preassembled hard lines available here: http://www.vintageair.com/2012catalog/20...age%2072%29.pdf
This is what I did on my Challenger, but I did have to cut and flare one end of one metal line:
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Good luck with your install
jess in ky
Yeah, it's hopped up to over 160...
Re: How to flare aluminum AC lines? [Re: jt4406] #1640741
07/02/14 08:11 PM
07/02/14 08:11 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
jess in ky
Wow, thanks for all the info! I'm going to do as you suggested and run hose to the on-engine connections and use hardline for the rest. I have the original lines I took of the car, so I can use those as a guide.
