70 roadrunner instrument cluster voltage regulator #1640721
07/01/14 05:21 PM
07/01/14 05:21 PM
new york
lilmoose102 Offline OP
new york
any comments on an easy way to replace the instrument cluster voltage regulator on my 70 roadrunner ? thanks
Re: 70 roadrunner instrument cluster voltage regulator [Re: lilmoose102] #1640722
07/01/14 08:11 PM
07/01/14 08:11 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
EZ..
Remove the radio & panel, 4 phillips screws and rear bracket..
Now U can reach in and pull out the regulator takes just a couple of minutes. Also be sure to check if U have the noise capacitor filter attached, some had it and others did not...
Just my $0.05...
Re: 70 roadrunner instrument cluster voltage regulator [Re: Sinitro] #1640723
07/02/14 06:04 PM
07/02/14 06:04 PM
new york
new york
thanks
Re: 70 roadrunner instrument cluster voltage regulator [Re: lilmoose102] #1640724
07/03/14 12:18 AM
07/03/14 12:18 AM
Monroe, LA USA
Carsavior Offline
Carsavior  Offline
Monroe, LA USA
You might want to think about the updated electronic one- that way it will be a one time only deal.
Re: 70 roadrunner instrument cluster voltage regulator [Re: Carsavior] #1640725
07/10/14 11:46 PM
07/10/14 11:46 PM
new york
new york
can you tell me about the updated electronic one? where can I get one,thanks
Re: 70 roadrunner instrument cluster voltage regulator [Re: Carsavior] #1640726
07/11/14 12:41 AM
07/11/14 12:41 AM
new york
new york
Pat,,can you tell my about the electronic one? thanks,Dan
Re: 70 roadrunner instrument cluster voltage regulator [Re: lilmoose102] #1640727
07/11/14 12:55 AM
07/11/14 12:55 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 70 roadrunner instrument cluster voltage regulator [Re: stumpy] #1640728
07/23/14 01:16 PM
07/23/14 01:16 PM
new york
new york
hey,Stumpy,at the end of the article you posted,the author says to e mail him for more info,or ordering a regulator,would you know his e mail or contact info ? thanks Dan
Re: 70 roadrunner instrument cluster voltage regulator [Re: lilmoose102] #1640729
07/23/14 01:48 PM
07/23/14 01:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
See if he is still listed on the user list here. 340_6Pak_cuda
Re: 70 roadrunner instrument cluster voltage regulator [Re: stumpy] #1640730
07/23/14 02:02 PM
07/23/14 02:02 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
