Re: Veers to the left...1970 GTX
[Re: Alaskan_TA]
#1640538
07/01/14 12:15 AM
07/01/14 12:15 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Check the adjustment on your brakes.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: magic1]
#1640539
07/01/14 12:16 PM
07/01/14 12:16 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Possibly "tire pull". If you have a floor jack, you might swap the front tires side-to-side and see if that helps. Always a good idea to have an alignment when you change wheels/tires. ![](/ubbthreads/images/graemlins/thumbs.gif) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
[Re: RUNCHARGER]
#1640540
07/01/14 04:21 PM
07/01/14 04:21 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I agree swap tires l to R.Ive seen quite a few radials pull to one side.Just remember if you had bias the alingment was probally set for them.Radials need more caster and less camber.Rocky
Chrysler Firepower
[Re: therocks]
#1640541
07/01/14 07:55 PM
07/01/14 07:55 PM
Posts: 4,959 WI
Dcuda69
WI
swap the fronts side to side....if it goes straight you're golden,if it pulls the other way you have a tire issue and it needs to be replaced. Have dealt with LOTS of tire pull issues over the years. And yes...I would still have the alignment checked/tweaked for the radial tires ![](/ubbthreads/images/graemlins/beer.gif)
