Chrysler mini van cooling fans? #1640022
06/29/14 10:53 AM
06/29/14 10:53 AM
Illinois
Mopar_Ray Offline OP
Illinois
Wife drives a 2006 Chryser town & country. Yesterday she asks me what's that noise? I went out and discovered the cooling fans were going on & off. Engine was cool. Killed the battery overnight, put battery charger on this morning. Fans started going on and off again. Also have a p0480 code. What do I check to correct?
Re: Chrysler mini van cooling fans? [Re: Mopar_Ray] #1640023
06/29/14 11:01 AM
06/29/14 11:01 AM
moparx Offline
moparx  Offline
sounds like one of the fan relays are shorted out.
Re: Chrysler mini van cooling fans? [Re: Mopar_Ray] #1640024
06/29/14 11:20 AM
06/29/14 11:20 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Have the battery fully charged and carbon pile tested. Minivan electronics do weird things when the battery is about to die.
Re: Chrysler mini van cooling fans? [Re: gtx6970] #1640025
06/29/14 04:16 PM
06/29/14 04:16 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
relay stuck, they are usually mounted on the drivers side rad support in front of the air filter box down below..
Re: Chrysler mini van cooling fans? [Re: AARCONV] #1640026
06/29/14 07:13 PM
06/29/14 07:13 PM
Illinois
Illinois
Finally found it, had to partially remove grille. Is there any way to test it?
