Meziere lectric 55GPH water pump leaking #1639906
06/28/14 07:55 PM
06/28/14 07:55 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
between the black motor part and the housing. It's 6 months old.
I took the pump off the motor and took off the 4 allen head screws to epose the impeller but don't know how to get to the housing to motor gasket.
Any help disassembling it? Does it disassemble from th front or with the set small allen screw on the impeller?
I reallt don't want to have to send the water pump back to Meziere.
Re: Meziere lectric 55GPH water pump leaking [Re: Sammy] #1639907
06/28/14 09:19 PM
06/28/14 09:19 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I couldn't get mine apart either. My armature ended up being bad so I sent it to meziere. They turned it around in about 2 hours, great service!
Mine was about 13 years old.
68 Barracuda Formula S 340
Re: Meziere lectric 55GPH water pump leaking [Re: Bad340fish] #1639908
06/28/14 11:23 PM
06/28/14 11:23 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I got mine apart and see nothing wrong. I'm thinking gasket in front letting water get through to the black moor area. Sending it back for service. I was hoping for a bad O ring between the motor and housing but there's no O ring.
