mopar e.c.u.? #1639892
06/28/14 06:43 PM
06/28/14 06:43 PM
United states wisconsin
bigblockbryan Offline OP
okay I want to know whats all the big difference in mopar e.c.u, right now im running a grey one what the local parts store. my car wouldn't see to run with a blue one. IT has a mopar performance ignition im gonna order a chrome e.c.u one my car ran perfect with that right now it seems to not like to idle im gonna turn my idle speed but does that make sense?
so this is what originally happend in my car I was cruising on the highway it died had no spark got it home.I had a blue box laying around,so I instlalled it fired up quit kinda acted like a ignition switch problem only ran on cranking postion with the blue box. replaced the ignition and went bought another e.c.u and now it runs just for some reason dosnt like to idle and am gonna buy a chrome box and see how that goes.
Re: mopar e.c.u.? [Re: bigblockbryan] #1639893
06/29/14 06:08 AM
06/29/14 06:08 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Off topic, but did you know that you start every thread with "okay" ?
Just something I noticed.
Re: mopar e.c.u.? [Re: Jjs72D] #1639894
06/29/14 09:51 AM
06/29/14 09:51 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
okay,that is hard to read also.
Re: mopar e.c.u.? [Re: mcmopars] #1639895
06/29/14 10:34 AM
06/29/14 10:34 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
okay, this isn't gonna go well is it? are you using a ballast resistor?
Re: mopar e.c.u.? [Re: bigblockbryan] #1639896
06/29/14 11:42 AM
06/29/14 11:42 AM
right now im running a grey one what the local parts store. right now it seems to not like to idle and went bought another e.c.u and now it runs just for some reason dosnt like to idle and am gonna buy a chrome box and see how that goes.
First I'd attack/fix the idle problem then see which way you want to go on the ECU's. Many options: parts house ECU. revenator. Pertronix. HEI module. MP chrome box. Just me I'd lean more toward a box/hot coil that could be run WO a ballast & push the limits a bit & carry spares
