Re: 70 Charger won't start
[Re: mnguy55]
#1639679
06/28/14 04:40 PM
06/28/14 04:40 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
All the + power for EVERYTHING except the big heavy cable to the starter for the starter motor power goes through the firewall bulkhead connector and then through the AMMETER on your gauge cluster before going to everything else in the car including your ignition switch. It is real common for the bulhead connection to get a bad connection and or FRY, and it is even more common for the AMMETER to fail. The Ammeter in these cars is in series with everything so when it develops a problem it affects power to everything.
Follow the positive wire from the battery to the starter relay to the bulkhead through to the other side of bulkhead to the ammeter etc with your voltmeter. Its tough but you can reach up under dash and see what kind of voltage you have at each side of ammeter. I bet somewhere in there you see a sudden large drop in voltage.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: pushbutton]
#1639684
07/01/14 02:41 PM
07/01/14 02:41 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Glad you fixed it. I was going to say on my 70' ocassionally even though in park it will not start. Push up on the shifter just a little harder & try again it usually will start. Sometimes it is just enough out of park (even though locked in position) to engage the neutral safety switch to keep it from starting. Just a thought.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
