How do I determine which electric OD trans I have?
#1638514
06/26/14 12:31 AM
06/26/14 12:31 AM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
So my son picked up this motor, auto od trans, computer & under hood wiring for an upcoming project. It from a 97 Dodge SST, or SSR or some other lettering . I know all automatic transmissions from 91 or 92 on were electronically controlled, the later the model, the more the computer controlled. So the question is, how does an old man like me determine which version of electronic controlled trans is sitting on the floor in front of me? Does each version have cast in, or stamped numbers somewhere, or are there wiring plugs that some have others don't? I know its the 727 version of whatever. Tell me how to determine which version of electric trans I have, please. Gene
Re: How do I determine which electric OD trans I have?
[Re: poorboy]
#1638515
06/26/14 03:06 AM
06/26/14 03:06 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
A 500 behind a 318
A 518 behind a 360
I am truckless..
[Re: 340SHORTY]
#1638516
06/26/14 03:13 AM
06/26/14 03:13 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
97 will have a 46RE. It has more electronics and computer control than the pre-96 46RH. The way to determine for sure is the plug on the driver's side by the gear selector facing up. 2 or 3 pin is RH, Multi pin (like 9-10) is RE.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: 340SHORTY]
#1638517
06/26/14 09:29 AM
06/26/14 09:29 AM
Guitar Jones
A 500 behind a 318
A 518 behind a 360
Not so. Many 5.2s have the 518(727 based) O/D trans behind them. Now a 3.9, not so much.
I'm assuming this is a gas engine, you didn't give much information at all except it's a something or other. But yeah up through 95 was the RH and 96 on the RE that doesn't have a governor. It uses a solenoid and sensor to get the valve body to perform the shift.
[Re: poorboy]
#1638518
06/26/14 02:37 PM
06/26/14 02:37 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The SST (Super Sport Truck) came only with the 5.9L engine and the 46RE trans.
[Re: 340SHORTY]
#1638519
06/26/14 02:58 PM
06/26/14 02:58 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
A 500 behind a 318
A 518 behind a 360
I flip full size Dodges 94-01 & buy them with bad transmissions & engines off the CL
I have yet to see an A500 in a full size V8 truck in those years Dakotas are a different story
[Re: BulletBob]
#1638520
06/27/14 02:39 AM
06/27/14 02:39 AM
poorboy
Freeport IL USA
Thanks for the info on the electrical plug by the shifter, that's what I was after. There are definitely more then 3 pins in that connection. If I ever stumble across one of these at a swap meet or something, I'll know what I'm looking at. I knew it was the 727/518 version because the pan kicks out at the dipstick area. Gene
