Re: drive shaft question
[Re: ffej]
#1638449
06/25/14 11:01 PM
06/25/14 11:01 PM
RapidRobert
I like 3/4-7/8". I'd think the non truck "regular" 727's have the same extension housing length. I'm assuming you are referring to output shaft spline engagement inside that ain't letting your yoke slide in as far as it did on the other 727
[Re: ffej]
#1638452
06/26/14 10:57 AM
06/26/14 10:57 AM
RapidRobert
& that end clearance is required. You have some drivetrain fore/aft location leeway with the slotted trans mount in the rear and the mtr mts possibly in the front. Not sure if the splines were not cut far enough on the output shaft. I'm assuming both trans' have the "flat" aftermarket type output shaft seal. A stackup of tolerances to some extent is normal but you've lost all your clearance. Not sure what happened but just tossin out ideas that hit me. I would call Tom at Cope & see what he says and Kunkel too (on here) if he sees this. an option which I did once is you can space the front hangars back a bit keeping in mind: tire/wheelwell clearance/rear shackle angle/housing to tank clearance/shocks get harder to fit on lower shockplate stud. First lets figure out what part/adjustment is wrong. Holler back with any news
[Re: ffej]
#1638453
06/26/14 02:50 PM
06/26/14 02:50 PM
Posts: 26,044 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the yoke slid into one 727 but won't slide into another the problem is most likely in the trans; could be a tight bushing or an obstruction in the tailhousing. Remnants of a shipping cover?
Also, look into the slip yoke to see if something is blocking full engagement.
