Engine Stand Adapter Plate?
#1638421
06/25/14 10:00 PM
06/25/14 10:00 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
guys, i'm looking for a way to mount my engine securely onto my engine stand. some sort of adapter plate to bolt to the back of the motor, to adapt to my stand. the stand i have doesn't allow the mounting arms to securely mount the 340 securely. i currently keep the hoist connected to the motor, for fear it will snap off the stand. i took the plate off the stand, and tried every conceivable combination of mounting the arms to the block, then plate. there's just no way to get them all done, evenly. thanks!
Re: Engine Stand Adapter Plate?
[Re: AndyF]
#1638424
06/26/14 11:20 AM
06/26/14 11:20 AM
Golden-Arm
Sunny South Florida
thanks for that. did you build it, or buy it?
[Re: AndyF]
#1638426
06/26/14 01:05 PM
06/26/14 01:05 PM
Posts: 671 Los Osos, Ca
CKessel
Los Osos, Ca
Nice job Andy! It always seems to be a compromise to get either an a or b-motor lined up on a stand and have enough clearance at the crank flange. If that stand in the first picture, not Andy's, is the one being used, boot it and get a better one or make the mount head like his.
Carl Kessel
[Re: Golden-Arm]
#1638427
06/26/14 01:19 PM
06/26/14 01:19 PM
RapidRobert
I ran into that once with a stand that fit a SB chebby but not ours. I'd take 2 or 4 arms to your welder & have him cut em in the middle & weld in some stock to lengthen em. Shouldn't take much time or $$$
[Re: dogdays]
#1638430
06/26/14 06:18 PM
06/26/14 06:18 PM
Challenger 1
Cincinnati, Ohio
to "securely mount the motor securely"? What do you mean?
People put bigblocks on those stands and they don't "snap off".
With all the hundreds of thousands of crappy engine stands out there, when's the last time you heard of an engine breaking a stand?
Now I do agree that it requires some jerry-rigging to put a SBM on a regular engine stand without running into the crankshaft flange. I ended up using 3/4" diameter nuts as spacers.
Andy's device looks very much like all the other Andy stuff: well-designed and constructed. If we all had his skills, what a wonderful world it would be!
R.
I have heard of many cheap engine stands snapping off. Ask 383Ron around here, he had one do it and posted a picture of it.
It's shame they have flooded the market with cheap tools like these. They have hurt people and damaged many engines I'm sure.
Golden Arm, did you try it all ways? Like flip the square head upside down and try it like that? Or are the arms that bolt to the end too short to clear the crank? Is so I would suggest having new arms built or buy something like Andy sells.
I built this engine stand in hi school, didn't realize j\how good of quality it was until years later. Had many 340s bolted to this one over the years.
That's all thread that I use, thread it in all the way into the block and use nut and washer and the other side. Been doing it that way for 20 years with tons of motors, plenty strong enough, don't need grade 8 bolts only 5. I rebuilt 3 super heavy international 404 gas truck engines on this stand. they weigh way more than a 440, but do use 7/16" hardware on the bell housing. Taller than the average stand, good thing since I'm 6'3" tall.
[Re: AndyF]
#1638432
06/28/14 12:10 AM
06/28/14 12:10 AM
RapidRobert
Andy is the center of gravity pretty close to the same between SB and BB so with a bolt hole change on a flat plate will I want the "height" to be pretty much the same? As in the cam tunnel centered
[Re: CKessel]
#1638433
06/28/14 12:19 AM
06/28/14 12:19 AM
Golden-Arm
Sunny South Florida
the stand is close, but not the same. (just a pic off the net) mine has a brace bar, that goes from the upright, to the bottom support.
the 4 arms don't line up, in a "box" type formation. if the arms were evenly spread out, the thing would be more stable. to actually line up all 4 holes, the arms are crossed, and there isn't a good spread on the distribution. the stand is nice, the mounting head is a pos.
yeah, this is what i meant. even though it has 4 arms bolted, it just isn't "secure". the engine droops a bit, and i use the hoist as a back-up. i did try the plate in all 4 axis', as well as the arms, in various combinations of arms, and holes in the block. the stand itself is a sturdy piece. the arms and head, aren't mopar small-block friendly.
i have hit up andy with a pm, and thanks to those who have replied.
