Dana 60, how much backlash? #163800
12/07/08 01:41 PM
12/07/08 01:41 PM
North Carolina, USA
Silverbullet2 Offline OP
North Carolina, USA
I swapped the 3.54s out of my 60 for a nice used set of 4.10s. Had to add 1 shim to get the pinion bearing preload "perfect". I dropped the carrier in and it has around .004-.006 backlash all the way around. Nice tooth contact pattern. Is it too tight? I'd rather be on the tight side than the loose side and I know there's room for a film of oil between the teeth. Anyone have the specs? Also any opinion about running synthetic 75-140 in a Dana 60, with the additive of course. THANKS!
Re: Dana 60, how much backlash? [Re: Silverbullet2] #163801
12/07/08 01:50 PM
12/07/08 01:50 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Used gears usually set up between .008"-.010" backlash. Any tighter causes the edge of the teeth to ride in the rough and howl.
I like conventional 85 W 140 gear lube. Synthetics make clutch type sure-grips a little lazy.
Re: Dana 60, how much backlash? [Re: DoctorDiff] #163802
12/08/08 01:08 PM
12/08/08 01:08 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
At 004-006, a couple of blasts and you 'll be right there at 008-010.
Re: Dana 60, how much backlash? [Re: DoctorDiff] #163803
12/09/08 03:30 AM
12/09/08 03:30 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
U Synthetics make clutch type sure-grips a little lazy.
Glad to hear I'm not the only one who noticed this.
