Re: Traction Issues...AGAIN !!!
[Re: superwrench]
#1637776
06/24/14 01:01 PM
06/24/14 01:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Try this pic....I think THIS tells the story !!!
A fellow racer just sent me this.....maybe hard to see at this sizing, but on a larger pic, the sidewalls are DESTROYED....and with pressure at 14# !!
Yeah.. your slamming them... also I think it needs a bit more air
[Re: superwrench]
#1637778
06/24/14 01:33 PM
06/24/14 01:33 PM
MR_P_BODY
I'm wondering if maybe I should put the new tires on my 10" rims.....although that might be a tad wide for a 9" tire.....
14# seemed to be what the car liked last season....I went up to 15# late Saturday during time trials but that was as far as I got by the end of the day.
A 10" rim will work fine
[Re: 383man]
#1637781
06/24/14 05:08 PM
06/24/14 05:08 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
I just never had the time to try 16-17#'s Ron....looking at the picture, I can see the rim is just killing the tire. The car weighs 3650 with me in it, so it's definitely a heavy weight. I ran 295/65 15 ET street radials at Pinks All Out with 17# in them and it hooked violently !!! It's just that I run at a couple of strips that (just like Dustin says), have track prep issues. The BIG tired cars don't have much issue, but I'm not cutting up a virgin Challenger's wheel wells to get some meat in there. I'm just trying to get rid of !!! It still hooked good at Mission Raceway last September, but their track prdep could have been masking my up-coming issue. I think Mike (Mr P Body) has hit the nail on the head.
[Re: superwrench]
#1637782
06/24/14 05:25 PM
06/24/14 05:25 PM
Triple Threat
Renton Washington
My car punishes the sidewalls as well. I would reccomend you install tubes with the new tires.
[Re: Triple Threat]
#1637787
06/24/14 07:34 PM
06/24/14 07:34 PM
Posts: 528 N.W. Indiana
DblOJoe
N.W. Indiana
What size tire and wheel do you run and how much air pressure if you don't mind me asking?
[Re: DblOJoe]
#1637788
06/24/14 07:43 PM
06/24/14 07:43 PM
Triple Threat
Renton Washington
That is a 29x10.5W, With Tubes on a 15x10. I run them about 12.25 PSI on my gauge, which is about 13.5 PSI on my buddies gauge.
[Re: superwrench]
#1637790
06/26/14 03:59 AM
06/26/14 03:59 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
You are right as its only money. And I never have enough of it. Let us know when you go back to the track on the new tires. Good luck , Ron
Re: Traction Issues...AGAIN !!! UPDATE*****
[Re: superwrench]
#1637795
07/21/14 02:13 AM
07/21/14 02:13 AM
superwrench
Well.... here it is in a nut shell..... Put a new set of 30 x 9 Hoosier's and new tubes on my 10" Prostars. First pass was a best 6.80 @ 103.60 Second pass was 6.75 @ 103.78 Then back-to-back 6.77's lifting in eliminations. Car got the 60 foots back to 1.45 and tracked straight as an arrow !!! I think I found my gremlins!!! Thanks for the feedback guys....
