Re: Headlight swap to LEDs from halogen, help?
[Re: RobX4406]
#1637160
06/23/14 01:21 AM
06/23/14 01:21 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Relays would be a REALLY intelligent choice.
x2
Do the relays first, to see what improvement you get. It's all the junctions and the headlight switch that's sapping the power to the headlights. If the Halogens still aren't doing it for you, try swapping in a set of H4s (and H1s [IIRC], if you have a quad light car.) They really put out a lot of light, and the beam is better controlled, so oncoming drivers are bothered by it.
