How can I repair my radiator overflow tank? #1636800
06/22/14 01:29 PM
06/22/14 01:29 PM
Cincinnati, Ohio
Challenger 1 Offline OP
Cincinnati, Ohio
The ribs by the mounting hole on my factory shroud on my factory radiator poked a hole in my repo overflow tank. So I'm assuming the repo mounting bracket is off a little?
Is there something I can repair the tank with after I get it real clean? TIA
Re: How can I repair my radiator overflow tank? [Re: Challenger 1] #1636801
06/22/14 01:38 PM
06/22/14 01:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The basic two part epoxy?
Re: How can I repair my radiator overflow tank? [Re: Challenger 1] #1636802
06/22/14 04:55 PM
06/22/14 04:55 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
A body shop with a plastic welder can fix that in about 3 minutes.
Earning every penny of that moderator paycheck.
DBAP
Re: How can I repair my radiator overflow tank? [Re: not_a_charger] #1636803
06/22/14 05:04 PM
06/22/14 05:04 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thank you, never thought of that.
Re: How can I repair my radiator overflow tank? [Re: Challenger 1] #1636804
06/22/14 05:39 PM
06/22/14 05:39 PM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
I've seen a guy use a butane torch and the same colored milk jugs to repair his GM tank that looks like this -- he may have used a larger soldering gun too -- I cannot remember. But it did work really well if I remember correctly -- and the repair worked perfectly for years.
Best of luck.
