440 timing #1636445
06/21/14 03:50 PM
06/21/14 03:50 PM
Delmar, NY
I
irisharse Offline OP
I
Delmar, NY
Adjusted the timing as directed on the 71 GTX. It runs much better, but doesn't spin the tires like it did prior to setting the timing. I also pumped more air in the rear shocks...would that shift the weight to make it not burn rubber??
Re: 440 timing [Re: irisharse] #1636446
06/21/14 10:37 PM
06/21/14 10:37 PM
What was your initial before when it was spinning the tires. What is it now when it wont spin em.
Re: 440 timing [Re: irisharse] #1636447
06/21/14 11:05 PM
06/21/14 11:05 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I never use the factory specs. for engine timing.... I always adjust it as far advanced as I can without it pinging.... Once you start putting aftermarket parts in a motor it changes where the motor likes it anyhow....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: 440 timing [Re: QTR MILR] #1636448
06/22/14 12:33 PM
06/22/14 12:33 PM
Delmar, NY
I
I
Delmar, NY
It was pretty far advanced before..like an inch. My reason for resetting to factory specs was hard starting when engine is warm. Stock 71 440 super commando. Factory setting is 5. I think i'll suffer through the hard starting to be able to spinm. Think a new starter?
Re: 440 timing [Re: irisharse] #1636449
06/22/14 12:54 PM
06/22/14 12:54 PM
one inch clockwise from TDC is 15.8 deg which ain't excessive plus you should be able to see that on the tab & should not be causing starter drag. Not a starter issue if it's OK at one setting & not at another tho a high powered mini starter will push thru that if you're pushing the limits with initial/scr but we're missing something. It's possible the dampener has slipped but that is rare & I'd rather k.i.s.s. 5 definitely ain't enough. So it runs better at 1 inch but the starter is cranky, correct so far? EDIT you can wire in an ign cutout & crank teh car with the key then close the switch while it is cranking. We had to do that on the stock car for it's labored cranking when hot. On/off switch in series with the black wire from dist to coil neg pri terminal (points) or blue/yellow wire to ECU (electronic) but it should not be labored at 15.8 initial plus ain't the 71's low compression?
