Re: 2000 ram with 5.2 wont rev over 3000 rpm.
[Re: rumblebee4232]
#1636356
06/23/14 01:54 AM
06/23/14 01:54 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Crank sensor issue.Should be the same sensor 96 or 97 up to end of run.
Leave the gun.......take the Cannoli's....Mike
[Re: Dono]
#1636359
06/24/14 09:45 AM
06/24/14 09:45 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
You swapped JUST the engine? Who's truck had the KB? Your buddies or the truck your buddy got the motor from?
Anyone mess with the cam?
I once accidentally mistook a dot for a circle on a 3 way timing set that was used and faded. I ended up with the cam about 30 degrees advanced and it would not rev past 3k rpm. Found, and fixed my mistake, and all was well.
**Photobucket sucks**
