Re: 360 and 5.7 crank pics [Re: MR_P_BODY] #1636331
06/21/14 07:25 PM
06/21/14 07:25 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I think I would always use a Wix racing filter.. they
dont filter the smaller partials BUT they also by pass
sooner which would supply oil at all times... JMO
I would eliminate the filter mounting point and take out some 90 deg angles too.
Matt
Re: 360 and 5.7 crank pics [Re: MattW] #1636332
06/21/14 07:26 PM
06/21/14 07:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Sorry, it's hard to be descriptive without really seeing.
Are the #2 & #4 mains drilled straight through from one side to the other, as in "I can see straight through the crank."?
Next question is are #2 & #4 mains drilled twice(hole every 90 degrees) or once (hole every 180 degrees)?
From what I can see in the pics, the holes are only drilled once, and are what I would consider "out of time" with the crank throws. This is mot likely why the mains are half grooved. You would probably be best off drilling the holes in the correct timed position, and plugging the holes as mr p described.
Re: 360 and 5.7 crank pics [Re: TRENDZ] #1636333
06/21/14 07:30 PM
06/21/14 07:30 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Getting pick up soon.
Cooking supper
Re: 360 and 5.7 crank pics [Re: MattW] #1636334
06/21/14 08:19 PM
06/21/14 08:19 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So all the mains are drilled straight through.
I made a mistake with two of the mains #2 and #4 are drilled all the way through at every 90 degrees.
Re: 360 and 5.7 crank pics [Re: MattW] #1636335
06/21/14 08:20 PM
06/21/14 08:20 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
#2
Re: 360 and 5.7 crank pics [Re: MattW] #1636336
10/13/14 03:55 PM
10/13/14 03:55 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
for Mrshred
Re: 360 and 5.7 crank pics [Re: MattW] #1636337
10/13/14 05:27 PM
10/13/14 05:27 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
is this only on the 5.7 cranks or 6.1 and 6.4 also?
Re: 360 and 5.7 crank pics [Re: MattW] #1636338
10/13/14 06:47 PM
10/13/14 06:47 PM
Toronto
mshred Offline
mshred  Offline
Toronto
for Mrshred
Thanks Matt! I have the same question as Ray, would this be the same for the 6.1 and 6.4 cranks also?
Either way, look forward to what you and Jesse find out
Re: 360 and 5.7 crank pics [Re: sixpackgut] #1636339
10/13/14 06:51 PM
10/13/14 06:51 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I have a 6.1 crank also I'll take a look.
Re: 360 and 5.7 crank pics [Re: MattW] #1636340
10/19/14 11:52 AM
10/19/14 11:52 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Factory 5.7 and 6.4 crank.
Re: 360 and 5.7 crank pics [Re: MattW] #1636341
10/19/14 11:54 AM
10/19/14 11:54 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
They changed the oiling holes on the 6.4. Gone are the holes straight through the crankshaft. Wonder why?
Matt
5.7
Re: 360 ,5.7 crank and 6.4 pics UPDATE [Re: MattW] #1636342
10/19/14 11:55 AM
10/19/14 11:55 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
6.4
Re: 360 ,5.7 crank and 6.4 pics UPDATE [Re: MattW] #2254104
02/15/17 05:02 PM
02/15/17 05:02 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
jhg
