Cut off switch for Trunk Mounted Battery Question? #1635656
06/19/14 04:43 PM
06/19/14 04:43 PM
Endicott, NY, USA
crazyjjk Offline OP
crazyjjk  Offline OP
Endicott, NY, USA
Per NHRA/IHRA rules do I still need a cut-off switch for a trunk mounted battery if my trunk does not need a key to open it? My trunk basically opens like a hood on a car with an external trunk latch so access is probably even easier than the hood on most cars at the track which now use an internal lever. I figured the argument for the external cut-off was you needed a key to open the trunk to access the battery. We are not talking a ten second car here just a street car with a very mild engine.
Re: Cut off switch for Trunk Mounted Battery Question? [Re: crazyjjk] #1635657
06/19/14 05:26 PM
06/19/14 05:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes you still need an external cut off switch. What if the trunk lid gets jammed in a crash. Rules are created to cover all kinds of odd happenings. There may not be time to open the trunk.
Re: Cut off switch for Trunk Mounted Battery Question? [Re: stumpy] #1635658
06/19/14 05:37 PM
06/19/14 05:37 PM
Endicott, NY, USA
crazyjjk Offline OP
crazyjjk  Offline OP
Endicott, NY, USA
If that is the justification why do you not need a cut-off switch if the battery is mounted in the engine compartment? Hood could be smashed shut also.
Re: Cut off switch for Trunk Mounted Battery Question? [Re: crazyjjk] #1635659
06/19/14 05:48 PM
06/19/14 05:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Because the gas tank isn't under the hood and there is a fire wall between the battery and the interior. You must have either an enclosed battery box vented to the outside or a panel separating the trunk from the interior with the battery in the trunk. Section 8 of the NHRA rules. It's for your safety as well as the track workers.
Re: Cut off switch for Trunk Mounted Battery Question? [Re: stumpy] #1635660
06/19/14 06:09 PM
06/19/14 06:09 PM
moparx Offline
moparx  Offline
and don't the new challengers as well as some others have the battery in the trunk from the factory ?
Re: Cut off switch for Trunk Mounted Battery Question? [Re: moparx] #1635661
06/19/14 06:12 PM
06/19/14 06:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think they are in a rear enclosed compartment separate from the trunk.
Re: Cut off switch for Trunk Mounted Battery Question? [Re: stumpy] #1635662
06/19/14 06:22 PM
06/19/14 06:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
There is a fiber board and carpet cover between the battery and the trunk. However, the battery should be vented to the outside from the factory.
- Stu Harmon
Re: Cut off switch for Trunk Mounted Battery Question? [Re: feets] #1635663
06/19/14 11:50 PM
06/19/14 11:50 PM
moparx Offline
moparx  Offline
but shouldn't the new iron also have a battery cutoff ? I certainly understand about the box being covered/insulated from the passenger compartment and vented to the outside.
Re: Cut off switch for Trunk Mounted Battery Question? [Re: moparx] #1635664
06/20/14 03:26 AM
06/20/14 03:26 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a marine case for my trunk mounted battery. But I also have a sheet of 1/8" thick metal right behind the rear seat back so it closes and seals the trunk off from the interior which is needed by the rules anyway. I drilled a few holes in the bottom of the box near the four corners that just go thru to the outside under the car to vent the battery. Works fine for me. I like the metal battery boxes that Jegs and others sell but I got this marine battery box free as the metal ones are not cheap as I believe they are over $100 dollars. But the metal ones are really nice. You can see the rod for the cutout switch also as the cutout switch is bolted to the battery box and I drilled a hole in the taillite lens to go thru to the outside. That way the only thing it changed was a small hole in the lens. If I ever took it out all I have to do is put a new lens in. Ron
Re: Cut off switch for Trunk Mounted Battery Question? [Re: 383man] #1635665
06/20/14 03:29 AM
06/20/14 03:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is the handle on the rod for the cutout switch. I was not going to drill any holes in my 63 so drilling a hole in the taillite lens was the best thing to do in my opinion that worked and did no damage by drilling a hole in the body. Ron
Re: Cut off switch for Trunk Mounted Battery Question? [Re: moparx] #1635666
06/20/14 10:28 AM
06/20/14 10:28 AM
Endicott, NY, USA
crazyjjk Offline OP
crazyjjk  Offline OP
Endicott, NY, USA
Yeah. My 08 Dodge Magnum has the battery under the back seat. I see a bunch of them running without a cut off. I know some GM cars from as early as 2000 have batteries under the rear seat also. I am not trying to be a jerk I just wonder why its limited to the trunk on older iron that NHRA/IHRA cracks down on. So it seems to be the cars with the battery under the back seat in the passenger compartment right in front of the gas tank would be more dangerous and require a cut-off but they are not required.
Heck some Chrysler's had the battery tucked between the front fender and the engine compartment. You would have to unbolt the entire inner fender just to get to it. That would be a nightmare if you had to get to it in a hurry.
And yes I have a divider between my passenger compartment and trunk and if I put it in the trunk it will be in a battery box. Seems this rule is just biased against cars who originally had a battery under the hood.
Like I said I am not being trying to be a jerk. It just seems that the way cars a built today with remote hood latches and batteries in odd places it is just as difficult to get to almost any battery not just those that have been relocated to the trunk.
Also the gas tank argument really doesn't hold water as with todays electric fuel pumps and fuel injection pushing fuel at high pressure, you are just as likely to have an issue with fuel in an engine compartment as from the gas tank. JMHO
Re: Cut off switch for Trunk Mounted Battery Question? [Re: crazyjjk] #1635667
06/20/14 10:52 AM
06/20/14 10:52 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
if you read the rule it says if the battery is moved from factory location.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Cut off switch for Trunk Mounted Battery Question? [Re: kissmyaspen] #1635668
06/20/14 01:31 PM
06/20/14 01:31 PM
Endicott, NY, USA
crazyjjk Offline OP
crazyjjk  Offline OP
Endicott, NY, USA
Thanks. I finally found that.
I guess that means even if I relocate the battery under the front hood to gain clearance say for an engine swap then technically I have to run a cut-off switch to the back of the car????
Re: Cut off switch for Trunk Mounted Battery Question? [Re: crazyjjk] #1635669
06/20/14 03:32 PM
06/20/14 03:32 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
There is also a ET/speed break.
Faster than 9.99 or 135, needs a cut off regardless of battery location.
Unless they changed the rule since 2012.
Re: Cut off switch for Trunk Mounted Battery Question? [Re: kissmyaspen] #1635670
06/21/14 09:41 AM
06/21/14 09:41 AM
moparx Offline
moparx  Offline
any of you youngsters know the factory location of the battery in my 33 dodge humpback ? [hint : it was not under the hood]
