Best product for cleaning engine compartment #1635608
06/19/14 02:19 PM
06/19/14 02:19 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Wondering what your favorite product is for general cleaning in the engine compartment. Just need to clean the surface grease and oil buildup off the engine, aprons, etc.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Best product for cleaning engine compartment [Re: MadMatt] #1635609
06/19/14 02:26 PM
06/19/14 02:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I like simple green.
Re: Best product for cleaning engine compartment [Re: MadMatt] #1635610
06/19/14 02:28 PM
06/19/14 02:28 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I pull into the car wash with the engine hot and spray WD-40 over everything I want to clean and then wash it off. Don't tell anybody...
...FAFO...
Re: Best product for cleaning engine compartment [Re: skicker] #1635611
06/19/14 02:32 PM
06/19/14 02:32 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
That sounds like an interesting idea. I've had great luck cleaning things with WD40. Think I might give that a try.
Re: Best product for cleaning engine compartment [Re: stumpy] #1635612
06/19/14 02:34 PM
06/19/14 02:34 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Actually, I used to use Simple Green foaming barbecue cleaner, but I can't seem to find the stuff anymore.
Re: Best product for cleaning engine compartment [Re: MadMatt] #1635613
06/19/14 02:35 PM
06/19/14 02:35 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
It works great and doesn't mess with anything that is polished or painted....
...FAFO...
Re: Best product for cleaning engine compartment [Re: MadMatt] #1635614
06/19/14 03:12 PM
06/19/14 03:12 PM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
Seen it at Lowes the other day.
Re: Best product for cleaning engine compartment [Re: crazyjjk] #1635615
06/19/14 06:10 PM
06/19/14 06:10 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
The guy that detailed my car said he uses Pledge.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Best product for cleaning engine compartment [Re: MadMatt] #1635616
06/19/14 06:43 PM
06/19/14 06:43 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Would you spray the engine down with the cleaner and rinse it off while the car is running? Is there any areas to avoid getting cleaner/water on? Never really cleaned an engine compartment before at the car wash.
Re: Best product for cleaning engine compartment [Re: MI_Custumz] #1635617
06/19/14 07:05 PM
06/19/14 07:05 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I used to be really obsessed with cleaning my motors at the car wash. Did it many times to a few different cars. I used to let my motor run also during the cleaning and hope it don't stall. If it did it was always water under the cap. There really isn't much under the hood to hurt IMO. Drying them is important, nice drive home from car wash usually worked. A nice blow with a air hose would be good down at the bulkhead connector.
To dissolve grease and grime, gasoline works pretty dang good, before the car wash used it many times also.
Now I have kick butt heated steam pressure washer that will remove grease and grime with no chemicals and I hardly use it on my motors now.
I use it all the time, the pressure washer, not not on my engine compartments lately.
Now that were talking about it, maybe a before and after picture session? With lot's and lot's of pictures!!
Re: Best product for cleaning engine compartment [Re: MI_Custumz] #1635618
06/19/14 07:05 PM
06/19/14 07:05 PM
Central TX
roe Offline
roe  Offline
Central TX
I did once. I just took some plastic grocery bags and some tape and covered stuff I didn't want to get wet like the alternator, etc. Than sprayed some decrease and oven cleaner, let sit, then rinse with the pressure hose.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Best product for cleaning engine compartment [Re: roe] #1635619
06/19/14 07:22 PM
06/19/14 07:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The best was commercial white wall cleaner, next is most of the purple cleaners. All these types have to go on dry, brush and keep wet then rinse with hp sprayer. If you missed a spot let it dry then repeat. They are good wax stripers on paint also, all the pinesap, buggs, chemicals, dirt that accumilate over the years will come off easy then rewax.
Re: Best product for cleaning engine compartment [Re: cudaman1969] #1635620
06/20/14 12:18 AM
06/20/14 12:18 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Castrol Super clean
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Best product for cleaning engine compartment [Re: 71yelladustr] #1635621
06/20/14 09:51 AM
06/20/14 09:51 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
There is nothing more difficult than detailing a Chromed Out Harley IMO!
For a show car underhood I recommend Cycle Wash followed by a electric leaf blower etc. Cycle Wash is just Amaizing stuff!
If you are cleaning a daily driver then the Simple Green/White Wall cleaners types work very well. I just don't like the wax stripping they do. It's pretty strong stuff and I wouldn't like to get it on my paint.
Newer cars, ONLY when cold. Older cars, warm seems to work best and yes, water in the distributor can be a bother. I don't worry about the starter, carburetor, wiper motor or the alternator, wash away!
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Best product for cleaning engine compartment [Re: MadMatt] #1635622
06/20/14 07:50 PM
06/20/14 07:50 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
One of my favorite all time tools.
http://www.crspotless.com
Wash my wife's SUV, no problem as no drying required. Same for my driver car, my motorcycles, auto engines,,,,,,and best of all for washing windows of the house,,,,no squeegee required.
Even in hot sun no drying required and with no spotting.
Wash anything as usual with regular tap water, and rinse with deionized water.
Put it on your Xmas wish list.
Re: Best product for cleaning engine compartment [Re: stumpy] #1635623
06/20/14 09:11 PM
06/20/14 09:11 PM
IN
ahy Offline
ahy  Offline
IN
Me too. A little paint thinner and a tooth brush is a good way to pre-treat any nasty spots.
Re: Best product for cleaning engine compartment [Re: skicker] #1635624
06/30/14 01:35 AM
06/30/14 01:35 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I wouldn't recommend the WD-40 wash if your reason for cleaning is to paint the engine/compartment!
