Who here is running a Addco front bar? #1635000
06/17/14 10:41 PM
06/17/14 10:41 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Question on mounting a front bar on a 73 Satalite
Re: Who here is running a Addco front bar? [Re: dart4forte] #1635001
06/17/14 11:40 PM
06/17/14 11:40 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
OLD stuff, but my Addco bar mounted with angle brackets which bolted to the control arms, and regular stock type brackets to the frame. But that was back in the mid '70s. '71 Sebring.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Who here is running a Addco front bar? [Re: dart4forte] #1635002
06/18/14 02:15 PM
06/18/14 02:15 PM
B-Body Bull Offline
B-Body Bull  Offline
I had one on a 77 Cordoba (isolated k-member like a 73 Charger) where the the end links attached to the strut rods instead of the lower control arm. Different than my 72 Roadrunner front sway bar.
Re: Who here is running a Addco front bar? [Re: B-Body Bull] #1635003
06/18/14 04:28 PM
06/18/14 04:28 PM
Mesa, Arizona
Mesa, Arizona
I'm dealing with a 73 Satilite wagon. Installed the bar last Sunday. It mounts below the k member instead of the bar running through it. The bar is too big. Now the bar hangs low under the chassis. Had the same issue with the PST bar I had on my 67 Fury
Re: Who here is running a Addco front bar? [Re: dart4forte] #1635004
06/18/14 05:45 PM
06/18/14 05:45 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Is it one of those designed with a loop to go over the support at the front center of the K frame? If so, is it installed upside down?
- Stu Harmon
Re: Who here is running a Addco front bar? [Re: dart4forte] #1635005
06/18/14 06:34 PM
06/18/14 06:34 PM
B-Body Bull Offline
B-Body Bull  Offline
If it is this bar :
http://static.summitracing.com/global/images/instructions/aco-806.pdf It is what I had on my cordoba. Is Your Wagon still for sale ? I saw it on the A body site http://www.forabodiesonly.com/mopar/showthread.php?t=218051 Cool Wagon .
Re: Who here is running a Addco front bar? [Re: feets] #1635006
06/18/14 07:24 PM
06/18/14 07:24 PM
Mesa, Arizona
Mesa, Arizona
The OEM bar goes through the K member. This bar is way too big to do that.
Re: Who here is running a Addco front bar? [Re: B-Body Bull] #1635007
06/18/14 07:26 PM
06/18/14 07:26 PM
Mesa, Arizona
Mesa, Arizona
If it is this bar :
Yes, that's my wagon. I decided to keep it. Yes, that appears to be the same bar. not sure on the Cordoba but does it's OEM bar go through the K member?
Re: Who here is running a Addco front bar? [Re: dart4forte] #1635008
06/21/14 10:33 AM
06/21/14 10:33 AM
B-Body Bull Offline
B-Body Bull  Offline
If it is this bar :
All the 73 -79 B bodies I had used this style bar. The pic is a 73 Charger. And, check this wagon out .
http://www.ebay.com/itm/Plymouth-Satelli...=US_Cars_Trucks
Re: Who here is running a Addco front bar? [Re: B-Body Bull] #1635009
06/22/14 11:36 PM
06/22/14 11:36 PM
Mesa, Arizona
Mesa, Arizona
Decided to take another look. Took everything apart. Finally able to thread the bar through the k frame. It was tight but it's in there
