Re: Torsion bar removal.
[Re: Aspen7695]
#163436
12/07/08 02:25 AM
12/07/08 02:25 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
i bought the tool but didn't have the room to use it with my headers. I was chucking the old bars so I just went the vice-grip route. If you plan on re-using the bar I've seen pics posted here using a bicycle handlebar fork - very clever I thought.
Ride eternal, shiny and chrome
[Re: 70blackfish]
#163438
12/07/08 08:56 AM
12/07/08 08:56 AM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
I just get the rear clips lose, front nut off, all pressure off and use a big pry bar between the lower control arm and K frame and just push it all out .
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: Fab64]
#163441
12/07/08 07:34 PM
12/07/08 07:34 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
I made a tool out of 2x4's, scrap metal and bolts:
![](http://i241.photobucket.com/albums/ff90/Fab_64/IMG_1493.jpg)
sweet that will fit right im my tool box, after tooling up to make a nice t-bar tools now i see again why bother if guys are still jambing lumber,leather,bfds,vicegrips,ect...under thier cars. my tools works on even hemi cars with 2 1/4 pipe headers, and no disassembly of front end parts,even leave tire on car. no marks on bars,im always r and r t-bar dropping driver side header or headers for more room to work ![](/ubbthreads/images/graemlins/wrench.gif)
MOPAR OR NO CAR
[Re: hemigod426]
#163442
01/02/09 04:32 PM
01/02/09 04:32 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I'm removing my torsion bars right now (never done it before). I loosened the adjusting bolt in the lower control arm to the point that the "bracket" (not sure what you call it) that goes the bolt goes through is loose. That is all I need to do (just loosen it until that bracket moves) correct, I don't need to completely remove that bolt right?
Joe
65 Barracuda 70 Challenger
[Re: jrwoodjoe]
#163443
01/02/09 04:57 PM
01/02/09 04:57 PM
Posts: 21,783 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Yup, if the block that the bolt threads into is loose you are good to go.
I used an old school bmx stem just because I had one lying around. I'm not sure if I originated the idea or not. They work good and the edges are already chamfered so you don't have to worry about putting any marks into the t-bar if it happens to slip a little.
[Re: Neil]
#163445
01/03/09 05:19 AM
01/03/09 05:19 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
No not always. You'll have to remove the upper control arm rubber-stop aswell. This will free up the last remaining tension on the bars.
By the way, on all the cars I've removed the Tbars out, I've never had to use a clamping tool or whatever. Pre'65 Mopars have the adjusters in the rear with a loose anchor. Once the tension is turned down you can wiggle the bars out of the front sockets.
On the later model Mopars it's, like said, handy to loosen up the lower control arm and knock it back a little.
[Re: mkbubs]
#163446
01/03/09 06:37 PM
01/03/09 06:37 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
I took a pair of vice grips and welded 2 pieces of angle iron to them, its listed here, in the Tech archives... Tech Archives I've used it a few times with great success and it was made with stuff I alredy had. Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
[Re: 440Satellite]
#163447
01/03/09 10:32 PM
01/03/09 10:32 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I bought the tool and it was still a fight, these things rust in place and they will take a lot of pounding to get moving.. Try some PB blaster and let it soak for a while. ![](/ubbthreads/images/graemlins/Twocents.gif) Here is a photo of the hammer, tool and the number 1 son whamming apart the steering column.
