Re: 426 Hemi block
[Re: robnbird]
#1631919
06/11/14 12:17 PM
06/11/14 12:17 PM
Posts: 3,505 DFW
mr_340
DFW
Re: 426 Hemi block
[Re: mr_340]
#1631920
06/11/14 06:03 PM
06/11/14 06:03 PM
Posts: 914 tn
robnbird
tn
Re: 426 Hemi block
[Re: Airwoofer]
#1631922
06/11/14 07:33 PM
06/11/14 07:33 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
What is the difference between a "hemi" block and a regular RB block? I know about the cross bolts on the mains. Is that all or are there differences in the way the heads attach?
Just curious...
A Hemi has bosses in the valley for additional head studs. Nuts are put on the studs from inside the valley. Here is a pic:
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: 426 Hemi block
[Re: DaveRS23]
#1631926
06/11/14 10:57 PM
06/11/14 10:57 PM
Posts: 993 Addison,IL
OUTLAWSSAA
Addison,IL
Guys World does not and will not have any iron blocks available. aluminum yes. Todd
I am curious as to why. Can you elaborate?
I have one and wonder if I should actually use it, now.
I talked to them at the PRI show. They said when Chrysler almost went into bankruptcy they took the molds back and that was that. He told me if I needed a block to walk over to the Bill Mitchell booth. So I walked over there and they told me all they were making was the aluminum blocks with no raised cam available.
Re: 426 Hemi block
[Re: sasquatch]
#1631933
06/12/14 03:59 PM
06/12/14 03:59 PM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
Yeah what he said. Do not worry about them, they are great blocks. Check your oil restrictor as some are not drilled. Easy fix in building not so much when assembled. TOdd
What is the oil restrictor?
Re: 426 Hemi block
[Re: robnbird]
#1631937
06/14/14 09:46 AM
06/14/14 09:46 AM
Quicktree
Does anyone know what is going on with Chrysler and the Gen 11 Hemi are they being produced by anyone . thanks
contact member 80arrow he has a complete mega block for sale I think,
