Exhaust manifold spacer /header flange ? #1631580
06/10/14 02:09 PM
06/10/14 02:09 PM
A Banana Republic near you.
JohnRR Offline OP
JohnRR  Offline OP
Are header flanges that you buy machine flat on both sides ?
A friend is crying that his HP manifold is to close to his valve cover and burning the paint off. He doesn't want to spend the money to have the manifold machined at angles and possibly crack down the road so the thought is to use a header flange and 2 gaskets .
Re: Exhaust manifold spaacer /header flange ? [Re: JohnRR] #1631581
06/10/14 02:20 PM
06/10/14 02:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most are not.. mainly because they figure you will
be welding on the flanges to build headers... but they
are flat enough to seal as is since he is just using
them as a spacer
Re: Exhaust manifold spaacer /header flange ? [Re: JohnRR] #1631582
06/10/14 02:46 PM
06/10/14 02:46 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
motorhome gaskets had a upper heat shield , try felpro oem
hi john, working at TASCA (bob III) Chrysler westerly ri
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Exhaust manifold spaacer /header flange ? [Re: JohnRR] #1631583
06/10/14 04:17 PM
06/10/14 04:17 PM
AndyF Offline
AndyF  Offline
I've made spacers before, it is a fairly simple process. Or use the motorhome gasket. I use the motorhome gasket on my Coronet engine which has HP manifolds on it.
Re: Exhaust manifold spaacer /header flange ? [Re: AndyF] #1631584
06/11/14 02:17 AM
06/11/14 02:17 AM
JohnRR Offline OP
JohnRR  Offline OP
He already has the motorhome gasket but thinks it's not going to make a difference as the manifold is real close to it ??? We'll break in the cam with one of my junky covers then swap on his cover , I've talked to schonefeild(sp?) they make the 1.750 tube to order so I might be able to get it with the bolt head side unchamfered ?
I don't have the time to make them when it would be done without paying for my time .
