Re: Dropping an engine in from the top
[Re: AZ67Dart]
#1630827
06/08/14 11:24 PM
06/08/14 11:24 PM
Posts: 15,457 Omaha Ne
TJP
Omaha Ne
[Re: AZ67Dart]
#1630829
06/08/14 11:38 PM
06/08/14 11:38 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I will be dropping a 360/727 in from the top of my 67 Dart.
It has a 73 K-member with spool mounts. I plan to have tri-y headers attached to the engine.
It looks like it will be necessary to remove the steering link.
Does anyone have any pointers?
I would not like to restart because I overlooked things.
How high should I lift the front end to get the correct angle?
Thanks.
You plan to drop it in with both Tri Y headers bolted up and attached to the engine??
Even with Tri Y headers, I don't think that will work. Or you are really taking a chance to scrape the headers against the side of the inner fenders and other stuff.
[Re: AndyF]
#1630830
06/08/14 11:39 PM
06/08/14 11:39 PM
Posts: 22,696 Bitopia
jcc
Bitopia
On my cars lately, I'm making the upper rad horizontal support removable, for easier engine swaps, FWIW.
ANDYF's picture shows the tightness on the oil pan I try to avoid.
[Re: AZ67Dart]
#1630832
06/09/14 12:24 AM
06/09/14 12:24 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
That would sure reduce the risk of scratching things.
So would dropping the K, and going in from the bottom...
[Re: AZ67Dart]
#1630834
06/09/14 12:34 AM
06/09/14 12:34 AM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
Personally I would remove the headers and after you get the engine started into place lay the headers into the engine compartment. Or my preference is to get the engine in and be sure that everything fits as it should then lift it back out a little to install the headers. My
