Axle centerline to u-joint centerline 8.75 vs 9" #1630456
06/08/14 01:00 PM
06/08/14 01:00 PM
3
340roadrunner Offline OP
I'm putting a 9" rear end in my cuda. It's a race car and a 4spd and I can't keep rear ends together... I have a brand new drive shaft with 1350 u joints and I'm curious if any one knows the difference between a 9" and 8.75 axle centerline to u joint? I'm hoping I won't have to get a new driveshaft.. That I can modify the one I have.
Thanks kevin
Re: Axle centerline to u-joint centerline 8.75 vs 9" [Re: 340roadrunner] #1630457
06/08/14 05:24 PM
06/08/14 05:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
8 3/4" = 12.35"
9" = 10.66"
I believe the 9" has different yoke lengths, so that dimension will vary.
Re: Axle centerline to u-joint centerline 8.75 vs 9" [Re: John_Kunkel] #1630458
06/08/14 06:39 PM
06/08/14 06:39 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
8 3/4" = 12.35"
9" = 10.66"
I have seen several different length yokes on the 9".
If you like drag racing, support your local track.
