'01 Ram 1500 4x4, crooked steering wheel
#1630084
06/07/14 06:53 PM
06/07/14 06:53 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I've noticed my steering wheel is 15-20* left of center when driving straight down the road. The truck pulls very slightly right when going down a straight section of road. I'm not sure it's not the crown of the road pulling the truck right, it's minor. Should I be looking for something bent on the left side? I recently replaced the front axle U-joints, but I don't see how this would be involved?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
Re: '01 Ram 1500 4x4, crooked steering wheel
[Re: J_BODY]
#1630089
06/08/14 05:14 PM
06/08/14 05:14 PM
GO_Fish
Maryland
Crawled back under for a look at the track bar. Nothing screaming worn out, but driver side axle seal is now leaking, guess I buggered it pulling or installing the axle for the U-joints. Going back in, Uggh. ![](/ubbthreads/images/graemlins/frown.gif) I'm not so concerned about the slight drift to the right. More concerned about the wheel being crooked left, and what caused that. Truck has 71k on original factory non-greaseable fittings. Maybe time to get a bunch of Moog parts with zirk fittings everywhere, get an alignment and be done with it for 10 years.
Scott B.
[Re: GO_Fish]
#1630090
06/08/14 09:03 PM
06/08/14 09:03 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
If all steering and suspension components are tight, then go have an alignment done, that will cure it,thing move slightly over years, needs to be adjusted. as the leaking axle seal go, not an easy back yard job, the left seal is next to the differential,( yes the ring gear, carrier assy needs to be removed), special tool to reach through the axle tube ( can make one with washers and LONG threaded rod,nuts) the right one is next to the axle actuator mid tube. again special tool.
[Re: moretoys]
#1630091
06/08/14 10:58 PM
06/08/14 10:58 PM
GO_Fish
Maryland
Okay, I understand. Front axle U-joints were done on jack stands in my gravel driveway, and that tested my patience big time. Sounds like the seal replacements are going to be a trip to the shop. You are also correct, if an alignment alone will fix things, I can push the replacement track bar, tie rod ends and ball joints down the road a year or two.
Scott B.
[Re: sthemi]
#1630093
06/12/14 10:40 PM
06/12/14 10:40 PM
GO_Fish
Maryland
I thought about leaving the fluid level lower, leaking seal not a big deal unless the axle went under water. But then I thought maybe the carrier bearings were meant to be partially submerged, and might get hot with less oil. I also am thinking about adding some Lucas to try and swell the seals, but that may just be a waste.
Scott B.
[Re: GO_Fish]
#1630094
06/14/14 08:46 PM
06/14/14 08:46 PM
Posts: 1,010 Sandy, OR
DART67GT
Sandy, OR
Odds are your axle seals are fine. It just puked out into the tube when you pulled the axles. I had the same issue with my 2000 Ram 2500 after a full front end rebuild. My steering was all over the place. Cause was mainly the steering box and track bar.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads
2000 Dodge Ram 2500 Quad Cab CTD
[Re: DART67GT]
#1630095
06/14/14 11:31 PM
06/14/14 11:31 PM
GO_Fish
Maryland
That is a good point about spillover into the tube. I'll have to watch it for a bit and see if it continues or stops. Thanks for the heads up!
Scott B.
