Dry sump pan mods #1629673
06/06/14 08:19 PM
06/06/14 08:19 PM
Janesville, WI
SpareParts Offline OP
Janesville, WI
Hey guys, I'm new to dry sumps but I'm wondering if it is okay to modify a bath tub style pan to work around stock steering? Could I cut and notch it to fit? Am I best to just run a tube like some of the aftermarket wet sump pans?
Can't afford to do a nice K and a rack right now so looking for solutions, car is a street strip car trying to be faster without turning the kit on
Re: Dry sump pan mods [Re: SpareParts] #1629674
06/06/14 08:21 PM
06/06/14 08:21 PM
AndyF Offline
AndyF  Offline
If you have a pickup in each sump you should be fine. It might not be the best solution but it should work.
Re: Dry sump pan mods [Re: AndyF] #1629675
06/06/14 11:17 PM
06/06/14 11:17 PM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
I'm not sure what a bath tub pan is. But if it's a regular oil pan yes use it.baffle the sump so it will keep the the oil in. Holes in bottom of baffle to let oil drain from shallow side
Re: Dry sump pan mods [Re: 72sat] #1629676
06/07/14 12:55 AM
06/07/14 12:55 AM
Janesville, WI
Janesville, WI
Cool, I wasn't sure what to call it but it reminds me of a bath tub lol maybe dragster pan is more accurate.
So cut what I have to just make sure the low points have pickups?
Re: Dry sump pan mods [Re: SpareParts] #1629677
06/07/14 01:25 AM
06/07/14 01:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How many suction ports on your pump... on mine I put
a wall in it up to the #3 main and had a pick up
at the rear(low area) on both rear sections..it was
a low profile style that I made up
Re: Dry sump pan mods [Re: MR_P_BODY] #1629678
06/07/14 02:14 AM
06/07/14 02:14 AM
Janesville, WI
Janesville, WI
Not sure Mr. P, haven't got it in front of me yet. Just trying to plan ahead so things almost go smoothly and I sorta kinda have a plan lol
Any recommendations on what size oil tank to run?
Re: Dry sump pan mods [Re: SpareParts] #1629679
06/07/14 02:40 AM
06/07/14 02:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I made my tank... it can hold 11 qts but I only run
9 1/2 qts in it.. right at the defuser plate(air separator
plate)
