Re: Anyone try a 400-3 adapted to a 4150?
[Re: rebel]
#1629654
06/08/14 09:01 AM
06/08/14 09:01 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I used a 750 alky Holley on a Domintor pattern manifold, and it worked great with that combo. I used a 2 inch adaptor upside down. I think the extra plenum volume was a help, running a 475 cube motor with that small carb.
[Re: gregsdart]
#1629656
06/08/14 11:05 AM
06/08/14 11:05 AM
Posts: 153 Bradenton, FL
Benforsp
Bradenton, FL
Greg,
That looks like what I may have to do I have a spacer designed to adapt a 4500 to 4150 it's just the transition is a mess inside the plenum. Here is a picture of it hopefully you can see the cloverleaf through the top of the adapter.
[Re: Benforsp]
#1629657
06/08/14 02:12 PM
06/08/14 02:12 PM
gregsdart
No pictures, but I rounded off all the flats , no sharp edges. Thank you Indy for leaving that intake manifold 1/2 done! Your best bet would be to get some pictures of intakes with the same sort of intrusion into the plenum, and copy it. The longer the runners, the better, IMHO. I remember having a pretty big pile of aluminum chips when done with mine.
[Re: AndyF]
#1629659
06/08/14 05:23 PM
06/08/14 05:23 PM
Posts: 31,046 Oregon
AndyF
