biggest cam and EFI
#1629136
06/05/14 02:24 PM
06/05/14 02:24 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
How big of a cam can a factory EFI 1999 5.9 magnum be set up to handle? It will be 410 cubes and around 11 to one compression. I can get different injectors...
Re: biggest cam and EFI
[Re: Adobedude]
#1629138
06/06/14 02:51 PM
06/06/14 02:51 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You're gonna want a standalone/laptop programmable efi like Megasquirt or something with a build like that. Then you can do whatever you want. Stock obd2 ecu is pretty stupid in comparison.
Mopar to the bone!!!
[Re: 72Swinger]
#1629139
06/06/14 05:37 PM
06/06/14 05:37 PM
HotRodDave
Kalispell Mt.
I know it will run with a mild cam and I will get a tuner of some sort but what is the limit within those parameters? I will get different injectors and such but with factory MAP TPS IAT... I just don't want to re-work the entire electrical system.
[Re: Duner]
#1629141
06/06/14 09:14 PM
06/06/14 09:14 PM
HotRodDave
Kalispell Mt.
Why do you think I want to get rid of all the factory gauges and such?
I want the truck (99 R/T I am trying to buy) to work like a factory truck, jump in bump the key, put it in gear and hit the gas with no waiting for it to warm up and come off the choke, all my factory gauges work just like the factory intended... but a whole lot faster. I don't have the time to build a whole new electrical system nor the skills to make it all work as reliably as the OEM, I am good at building engines so I want to push right up to the limit of what can be made to work fairly easily within those parameters.
