Page 2 of 3 1 2 3
Re: Disappointment at the dyno [Re: 70Drop] #1628820
06/04/14 11:26 PM
06/04/14 11:26 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Your cars performance is exactly what it should be doing with 410 RWHP. At 3200#, it should be running 11 teens, and your MPH is good for that.You may not like the numbers the engine put out, but its doing what it should at that horsepower. You'll simply need more HP and torque to do what you want to do, and I'm not sure its in that combo as it sets right today.
Your heads are a mystery, and with a 500" motor, probably trouble.
Keep this in mind, Stock eliminator cars, at almost 3800 pounds, and .490 cams, can run under 10.50s. They do this with efficiency, all the way thru the cars set up. And before all the naysayers jump on the " yea, but thats one of those trick stockers", it doesnt matter. The math is the math. They work with way less cylinder head, and way less cubic inches. There is always MORE in the chassis etc.
What are the 60' times, and 1/8 th mile et and mph?
RIP Monte Smith
Re: Disappointment at the dyno [Re: DaveRS23] #1628821
06/04/14 11:27 PM
06/04/14 11:27 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I assume the pistons are flat tops at 10.5-1. I don't think timing will help, as 35 should be all it can take. If it were me, I'd find someone that runs stock eliminator and pick his brain. They get a ton out of not so much.
Re: Disappointment at the dyno [Re: 70Drop] #1628822
06/04/14 11:27 PM
06/04/14 11:27 PM
AndyF Offline
AndyF  Offline
500 inches with standard port heads will have a torque peak in the low 4000's and a HP peak in the low 5000 range so I don't see a problem there. That is just how the physics works out.
My guess is that the heads aren't very good even though they have a ton of work and they probably cost a lot. But it could be a bunch of other little items that are dragging you down.
Do all of the normal stuff and see if you find any clues. Leak down test, look at the plugs, double check the valve lash, double check timing, AFR, etc. I've seen a lot of weird stuff over the years such as a collapsed muffler, or a sticking e-brake that cost 50 hp on the dyno. I had a Mopar ignition system once that ran fine on the street but cost me over 60 hp on the dyno when compared to a MSD ignition. A burnt plug wire costs 30 hp on my Coronet and isn't noticeable when driving.
Re: Disappointment at the dyno [Re: AndyF] #1628823
06/05/14 12:27 AM
06/05/14 12:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Andys right. Reference the Mcfarland formula.
Jim McFarland's formula for calculating the torque peak in and engine. The formula is: the smallest CSA of the intake track x 88200 divided by the cubic inches of one cylinder.
RPM at torque peak = cylinder head cross section area X 88200 / Cylinder volume.
Re: Disappointment at the dyno [Re: 451Mopar] #1628824
06/05/14 12:59 AM
06/05/14 12:59 AM
California
70Drop Online content OP
70Drop  Online Content OP
California
Here's my timeslip for reference. I'm in the left lane. Interestingly, the guy on the right (Mark Kirby) ran a 10.85 with basically my same MPH. I've got traction problems on top of everything else
Re: Disappointment at the dyno [Re: 70Drop] #1628825
06/05/14 01:22 AM
06/05/14 01:22 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
4 tenths throughout the run, that tells me the same weight to horsepower between the two cars just one left better then the other. It happened in the 60' time.
Getting the combo exactly right is real important.
Converter,Cam,Gears all have to work together.
Re: Disappointment at the dyno [Re: Biginchmopar] #1628826
06/05/14 01:35 AM
06/05/14 01:35 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
10 second car that leaves like a 12.00 car.
The converter and chassis need a ton of work.
Re: Disappointment at the dyno [Re: RobX4406] #1628827
06/05/14 01:53 AM
06/05/14 01:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep
Re: Disappointment at the dyno [Re: MR_P_BODY] #1628828
06/05/14 02:42 AM
06/05/14 02:42 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The cars have similar power, as witnessed by the 60ft to 330 numbers, the backhalf numbers, as well as trap speed. While a quest for power is fine, power is useless if you can't put it down. WORK ON THE CAR.
Monte
Re: Disappointment at the dyno [Re: Monte_Smith] #1628829
06/05/14 03:34 AM
06/05/14 03:34 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
"I've got traction problems on top of everything else"...you say.
You're peeing up a rope until you make it hook.
The heads "been flowed and should support 550hp"
Until you know what they flow and WHERE your combo can't be optimized.
Re: Disappointment at the dyno [Re: cudadoug] #1628830
06/05/14 05:58 AM
06/05/14 05:58 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I think you could make small gains here and there with changes, but the big ? is the cylinder heads.
Re: Disappointment at the dyno [Re: 70Drop] #1628831
06/05/14 08:20 AM
06/05/14 08:20 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The fuel pressure is 7.5 and there hasn't been any problem with fuel delivery. Holley Blue pump.
7.5 psi in the traps? Fuel delivery usually shows up as low power
Re: Disappointment at the dyno [Re: BSB67] #1628832
06/05/14 09:28 AM
06/05/14 09:28 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
The car in the other lane is probably close to a "best case" scenario. His 60' is REALLY good for the ET. You could get your car down to the low 1.5's or high 1.4's without too much trouble...that should get you into the high 10's.
What is your tire size and gear?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Disappointment at the dyno [Re: FlyFish] #1628833
06/05/14 09:43 AM
06/05/14 09:43 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I would also add that if you want 10.60's, you will need more power....and like others have said, it is probably your heads that are holding you back.
For what its worth, I have the little brother to that cam (Comp cams XR286R) in my 10.8:1 compression small block stroker with 90 less cubes that runs mid 10's in a 3200 lbs car...but my heads flow really well (thank you Ryan Johnson @ SDSS), that's why I think its your heads that are the bottle neck.
Re: Disappointment at the dyno [Re: FlyFish] #1628834
06/05/14 10:20 AM
06/05/14 10:20 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
It was mentioned earlier and I'll repeat, you need more carb,ie. a 1050 Dominator, an 850 is not adequate for 500 inches. When you get enough air and get the chassis sorted out where it will hook I think you'll be close to where you need to be. At that point the heads may become the bottle neck to more power.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Disappointment at the dyno [Re: MR_P_BODY] #1628835
06/05/14 10:32 AM
06/05/14 10:32 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Looks like you have the same problem I have...your 60ft sux. I'm spinning how are you getting out?
Re: Disappointment at the dyno [Re: Mr.Yuck] #1628836
06/05/14 11:14 AM
06/05/14 11:14 AM
Anyone that works with Mopars on the dyno knows that 35 is not enough timing--that is at the point where a few more degrees means big leaps in HP usually--many like around 41 or so in my experience--now I know it all comes down to combustion chamber--piston top etc but 35 will not get it when seeking best power numbers in most cases
Re: Disappointment at the dyno [Re: ] #1628837
06/05/14 12:42 PM
06/05/14 12:42 PM
an8sec70cuda Offline
With those heads, I'd start at 38° total timing and go up from there. It'll like the extra timing.
Don't be tempted by the big B1 intake you mentioned in the classifieds...it will KILL your lowend torque.
I think the power it made is right in line w/ what you have and what the car runs. Get the 60' down w/ either some chassis tuning and/or torque converter and it'll run much better.
When you decide you want to go faster and make more power, I'd do a big heads/cam/intake/carb change.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Disappointment at the dyno [Re: an8sec70cuda] #1628838
06/05/14 12:58 PM
06/05/14 12:58 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
The previous owner of the heads said they had been flowed and should support 550 HP.
That chassis dyno is showing what looks to be 550 HP at the crank. If you lose 20% that is over 100 HP.
Your car almost runs like my fish did with the 416 (500 crank HP, 3050# with me in it, 3.91 gears). The ET and MPH are just a bit slower. IMO the other guy on that slip shoulda been a lot faster at the 1/8th based on his 60 and ET. He was doing something wrong or sandbagging.
Re: Disappointment at the dyno [Re: 70Drop] #1628839
06/05/14 02:10 PM
06/05/14 02:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Based on what I'm getting from you guys, I'm first going to bump the timing to 38-degrees and get the AFR right. Do you think I would get anything from retarding the cam?
It sounds like I'm not going to make a lot more power without a change in heads or cam.
Timing needs vary by head material design and chamber shape. My 906`s made 615 hp 580 tq on engine dyno and went 10.40`s at 3200 lbs. Tighten the plug gap to around .035 and see what happens. Bigger cam would help as stated along w/a better intake if you can swing it..........good luck.
Page 2 of 3 1 2 3
