Page 1 of 3 1 2 3
Disappointment at the dyno #1628800
06/04/14 07:34 PM
06/04/14 07:34 PM
California
70Drop Online content OP
70Drop  Online Content OP
California
Hi,
It's been a while. I'm finally getting serious with my Duster street/strip car. I had it on the dyno and was unhappy with the results (see dyno sheet attached to the next post). The car has run a best 11.26 @ 121 mph. Here are the specs:
440/500 with 10:1 compression
Comp Cams solid roller: 254/260 @ 0.050, 0.582/0.588 lift. Installed straight up. XR292 grind number, if that helps.
Heavily ported 906 heads with Stage VI -type rework (pinch area externally welded for material to straighten out the ports, intake rockers offset). The bowls have been opened way up, guides shortened, short-turn smoothed, etc. The previous owner of the heads said they had been flowed and should support 550 HP.
Edelbrock Torker II single-plane intake with 1-inch spacer.
Mighty Demon 850. I don't have the AFR readout, but it was just a bit rich on the dyno.
Timing @ 35-degrees total.
Headers are Pro-Parts-type 2-inch. Chambered mufflers were in place during the dyno pulls.
727 trans., 9.5" converter, 8.75 rear.
Everything sounded and felt fine during the pulls.
Thoughts?
Re: Disappointment at the dyno [Re: 70Drop] #1628801
06/04/14 07:36 PM
06/04/14 07:36 PM
California
California
Whoops. Here's the dyno sheet.
Re: Disappointment at the dyno [Re: 70Drop] #1628802
06/04/14 07:49 PM
06/04/14 07:49 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
This was a chassis dyno correct? So you're laying down 410 rear wheel hp, not engine hp. You've got to figure you're losing about 20% though an 727, converter, and heavy rear-end. 410/.8 = 512hp.
Did you tune the A/F on the dyno? If not, you should! You could pick up a decent amount of power, and have better throttle response if your A/F is indeed off a bit. Honestly, most people get let down on dynos. If your car is running the number you're looking for and you know your engine is tuned correctly...let it go, and keep on racing.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Disappointment at the dyno [Re: 70Drop] #1628803
06/04/14 07:57 PM
06/04/14 07:57 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Hi,
Thoughts?
IMO Torker II isn't all that great. I always liked the Holley Street Dominator, but there's probably better intakes nowadays...maybe the Indy or a Victor intake?
Re: Disappointment at the dyno [Re: BigDaddy440] #1628804
06/04/14 07:59 PM
06/04/14 07:59 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Engine or Wheel Dyno?
Engine = not so good
Wheel = pretty good
That is a lot of inches for that kind of head, that's why it falls off as fast as it does.
Re: Disappointment at the dyno [Re: 451Cuda] #1628805
06/04/14 08:04 PM
06/04/14 08:04 PM
dogdays Offline
dogdays  Offline
Stock head bigblocks seem to work best at 38 degrees total timing. That also could be worth a horse or two.
It's easy to get fooled in this day of "800hp" engines. Not that I would suggest that many of these numbers were achieved by trickery, but.......
What does your car weigh?
R.
I estimated your car at 3800 lb at the line. That calcs out to 540 flywheel hp. Considering that you have heavily worked but still 906 heads, and a not too insane camshaft, it doesn't sound too bad. There's probably another 50hp in it by tuning.
If you want a big step up, you need better heads and a bigger camshaft, but then driveability might just go out the window.
Re: Disappointment at the dyno [Re: BigDaddy440] #1628806
06/04/14 08:20 PM
06/04/14 08:20 PM
California
California
Yes, that's wheel horsepower. I did not set the AFR on the dyno, but it was close and the dyno-tuner said I should be OK if I leaned it out two jet sizes all around.
One kind of interesting thing he said is that I should be running a 0.035-inch spark plug gap. I'm running like 0.055 now. I figured I was OK, as I've got a strong spark from my MSD Digital 6. Also, the car never misfired or anything like that. I didn't know what to think about that comment.
I'm looking to run this car in a few Nostalgia events, so I need to get it to run the D-gas index (10.60). I know I've got some work ahead of me, so I need some advice on what to do next. The car is 3,200 lbs. with me in it.
Re: Disappointment at the dyno [Re: 70Drop] #1628807
06/04/14 08:25 PM
06/04/14 08:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats not bad to the wheels as was said thats about 500hp at the crank. Ron
Re: Disappointment at the dyno [Re: 70Drop] #1628808
06/04/14 08:27 PM
06/04/14 08:27 PM
johnmilner Offline
johnmilner  Offline
baby cam.
Re: Disappointment at the dyno [Re: 70Drop] #1628809
06/04/14 08:27 PM
06/04/14 08:27 PM
Carson City, Nevada
Carson City, Nevada
If you're trying to run D/Gas (10.60 Index) at 3200lbs you need 532HP to the wheels. You need to be able to run the index even when the air is bad so I would think you need somewhere between 560HP-575HP to the wheel. I don't believe your combo will get you there.
Re: Disappointment at the dyno [Re: 451Cuda] #1628810
06/04/14 08:31 PM
06/04/14 08:31 PM
California
California
I've been told before that the Torker II is less than state-of-the-art. I'm getting tempted by an B1 I see on the board . . .
Re: Disappointment at the dyno [Re: johnmilner] #1628811
06/04/14 08:36 PM
06/04/14 08:36 PM
California
California
baby cam.
This I've heard as well. I'd like it to be a streetable car, so I went small (at the recommendation of the Comp Cams tech). Now I'm thinking it's too small. The engine idles pretty smoothly at 800 rpm and has a ton of torque. I can probably go bigger on the cam and still be able to drive to the track.
Re: Disappointment at the dyno [Re: 70Drop] #1628812
06/04/14 08:37 PM
06/04/14 08:37 PM
The Great White North
RAMM Offline
RAMM  Offline
Running your number is possible; however, that output is not stellar considering the inches and extensive (although unknown) headwork. I doubt sparkplug gap would be a culprit of any significance. Make sure your advance curve was correct (all in by at least 3000 rpm) and somewhere between 32-38 degrees total. I've never seen a Demon that wasn't way too lean already OOTB. Also--While the cam specs look good--I've never seen one of those work all that well. Sorry--probably more questions than answers. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Disappointment at the dyno [Re: 70Drop] #1628813
06/04/14 08:51 PM
06/04/14 08:51 PM
AndyF Offline
AndyF  Offline
Take a look at the article in the tech archives on my old 470 engine. That engine made 470 hp at the rear wheels with a MP .528 cam and HP manifolds. The big difference between our setups is the fact that I had a manual trans and you have a 727. The automatics suck up a lot of power on the chassis dyno.
Could be a bunch of little things, hard to say without spending some time swapping parts. I do know that it is hard to get cast iron heads to work right, but it isn't impossible. Some guys can really make them work. The Torker II intake isn't all that great but I doubt it is costing you a ton of power. Carb and ignition could be off or there could be a different issue.
http://www.moparts.org/Tech/Archive/bb/550hp.html
Re: Disappointment at the dyno [Re: AndyF] #1628814
06/04/14 09:07 PM
06/04/14 09:07 PM
NC
440Jim Offline
440Jim  Offline
NC
That cam has less duration than I like.
500 CID engines eat cam duration for breakfast, even a 440 CID with 10 CR could run 256 deg at 0.050", IMO. If you ever decide to put more cam into it, don't go 5 degrees, try around 265-270 at 0.050"
All that being said, 11.26 isn't that bad; an 11.00 goal might be realistic without major changes.
Re: Disappointment at the dyno [Re: AndyF] #1628815
06/04/14 09:10 PM
06/04/14 09:10 PM
California
California
Based on what I'm getting from you guys, I'm first going to bump the timing to 38-degrees and get the AFR right. Do you think I would get anything from retarding the cam?
It sounds like I'm not going to make a lot more power without a change in heads or cam.
Re: Disappointment at the dyno [Re: 70Drop] #1628816
06/04/14 09:27 PM
06/04/14 09:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Torker II not the best intake and try 38* total. I'm guessing 550 is not at the wheels???? if so it should run better than 11.20s. Try some more timing and lean it up some.
Coming soon!!!!
Re: Disappointment at the dyno [Re: 70Drop] #1628817
06/04/14 09:49 PM
06/04/14 09:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Like someone said, there could be a bunch of power left on the table that you just need to find. Exhaust, intake, A/F ratio, timing, cooling, cam timing, lash,....
How is the fuel pressure....is peak power really at 5200 rpm?
And your heads are a big unknown.
Finally, what is the cranking cylinder pressure?, and who's converter are you using?
Re: Disappointment at the dyno [Re: BSB67] #1628818
06/04/14 09:58 PM
06/04/14 09:58 PM
California
California
The fuel pressure is 7.5 and there hasn't been any problem with fuel delivery. Holley Blue pump.
Cranking cylinder pressure is very high - like 160 psi.
And yes, peak HP comes in at like 5200, which makes me think I'm running out of air.
Re: Disappointment at the dyno [Re: 70Drop] #1628819
06/04/14 10:06 PM
06/04/14 10:06 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The heads are the biggest question mark. The low peak is the biggest indicator to me. After that, the combo could probably use more carb.
I have a similar sized cam in my 500" but mine makes about 60 more ponies and peaks at 5,600. The biggest differences in mine are; another point in comp 10.9, MCH ported Eddies, -3 Indy intake, and 1050 Dominator.
This is in a 3,450lb street car with 727 and 3.91s.
Master, again and still
Page 1 of 3 1 2 3
