92 Ram LE Headliner #1627416
06/01/14 09:25 PM
06/01/14 09:25 PM
Wausau,Wisconsin
Kilrbee Offline OP
Kilrbee  Offline OP
Wausau,Wisconsin
My 1992 Ram Headliner is Falling down/ Seperating from the backing board.Does anyone have a good fix or idea on how to fix it?
Re: 92 Ram LE Headliner [Re: Kilrbee] #1627417
06/02/14 12:02 AM
06/02/14 12:02 AM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Get it recovered because you'll never get the original cover to stick back to it, my
Re: 92 Ram LE Headliner [Re: 98RAM1500] #1627418
06/02/14 01:23 AM
06/02/14 01:23 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I used 3M headliner adhesive. There are several available, I can see what I used on my 93 as it worked pretty well. It was really coming down above the doors and I was able to spray it in the middle then work my way out to the edges.
JB Rhinehart, Realist
A-Body's RULE!
Re: 92 Ram LE Headliner [Re: Rhinodart] #1627419
06/02/14 07:52 PM
06/02/14 07:52 PM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
The original headliners have some type of foam and its the foam that's disintegrating. I took mine out and bought similar headliner material from a fabric store and simply replaced it. Used spay adhesive as suggested by Rhino.....
Re: 92 Ram LE Headliner [Re: Lugnutz] #1627420
06/05/14 07:20 PM
06/05/14 07:20 PM
Guitar Jones Offline
Check out the FAQ/Knowledge base thread in the 1st Gen Ram section at dieseltruckresource.com There is a write up in there on how to do it along with a whole barge load of other info on the 1st Gen trucks.
