High Helix Littlefield 14:71
#1627379
06/01/14 06:44 PM
06/01/14 06:44 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
Are there intakes for a 440 that fits?
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: High Helix Littlefield 14:71
[Re: FastmOp]
#1627382
06/02/14 06:58 PM
06/02/14 06:58 PM
fed
Stockholm, Sweden
Is that the Modman intake that Indy offer?
[Re: FastmOp]
#1627385
06/03/14 03:08 PM
06/03/14 03:08 PM
fed
Stockholm, Sweden
Thinking of buying, supposed to 14/71
[Re: 23T Hemmee]
#1627388
06/03/14 10:58 PM
06/03/14 10:58 PM
I had Littlefield open up the bottom on my 14-71 to decrease this issue, it now has two pie openings.
[Re: 23T Hemmee]
#1627389
06/04/14 10:36 AM
06/04/14 10:36 AM
Posts: 4,210 New York
polyspheric
New York
depending on the manifold design may direct more of the fuel/air charge into the front of the manifold
All clocked (rotated lobe) blowers direct more charge into the front of the manifold. The better ones compensate for this with a triangular discharge port, the worse ones don't. The sides of the triangle generally follow the rotor angle.
Important: references to "helix angle" are not the angle of the rotors, it's the number of degrees of twist the rotors make front to back. A 10" long "60° helix" rotor will have twice the angle as a 20" rotor, etc. This is one reason why rotor swaps between different Eaton M-series sizes aren't more successful...
Boffin Emeritus
[Re: 23T Hemmee]
#1627390
06/04/14 11:55 PM
06/04/14 11:55 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
It looks to be the standard blower base stud pattern. The issue will be, if its a true Hi-helix, is that it will probably have the triangular pie-shaped bottom opening toward the front instead of a full length opening, and depending on the manifold design may direct more of the fuel/air charge into the front of the manifold. That's why you see a lot more set-back blower setups, they are trying to locate the opening of the blower more toward the center of the intake manifold to even the fuel distribution.
I am using a delta opening from The Blower shop with a BDS intake and yes it feeds to the front but I also have an intercooler that corrects that now for the most part.
