Re: RB rocker arms w/ roller cams
[Re: '72CudaRacer]
#1627357
06/02/14 04:35 PM
06/02/14 04:35 PM
Posts: 1,608 westerly, ri. usa
440lebaron
westerly, ri. usa
I think anything under .650 lift would be a waste of B1 heads
gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 68Bullet]
#1627359
06/03/14 06:28 PM
06/03/14 06:28 PM
Thumperdart
State of confusion
I can tell you from experience that I would be hesitant to run any aluminum rocker on a high RPM engine with high lift cam or spring over say 500 lbs open. I ran a set of Dove roller rockers (sold by Hughes in 2004 until they changed to an in house design) on my 383 with COMP street mechanical roller cam. I broke 2 rockers before I wizened up and bought the COMP magnum rockers, made of steel. Aluminum will stress fatigue and eventually break given a high enough number of cycles. Steel on the other hand, potentially will last an infinite number of cycles if the stress is low enough.
I cannot tell you where the cutoff would be where aluminum is guaranteed to break. My aluminum rockers lasted 10k miles of street driving with 500 pound open pressure springs at only .550 lift. Some may say that is a decent lifespan for aluminum rockers. But once one broke (and I thought it was an isolated incident), the second broke only 60 miles later. The hassle, cost and downtime of all of the repair work makes me wish I'd ponied up for the COMP rockers up front.
Bottom line is to discuss your application and get a guarantee from the seller. Otherwise you should always err on the side of caution and pony up for better components. Granted to I did not consult my application with Hughes when I ordered my rocker arms, BUT Hughes would not support me AT ALL when my rockers broke and I basically went to another vendor to buy the COMP rockers. Don't forget that not all rockers all have the same geometry, which means new push rods may be needed as well, so it's not as easy as JUST replacing the rocker arms.
Last note is to use high quality fasteners to hold down your rocker arms!
This is interesting. Aren`t Jesel, Harlands and T&D Alum. Been taking my H&S`s past 7000 for years and I know of 8000+ rpm motors w/Alum. rockers.............
[Re: 68Bullet]
#1627360
06/03/14 06:31 PM
06/03/14 06:31 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Dove rockers are marginal at best in a flat tappet application so I find it unfair to lump it in with "any aluminum rocker" After all T&D and Jesels are aluminum!
[Re: Thumperdart]
#1627364
06/03/14 10:47 PM
06/03/14 10:47 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Hear what you`re sayin and as stated, comparing Dove to any of the mentioned bad azz rockers is apples to oranges and if you`ve been around long enuff you should of heard that by now...........
Right on Dom....
RIP Monte Smith
