Sweptline 18" Wheels?? #1627214
05/31/14 11:55 PM
05/31/14 11:55 PM
Maine
1965Monaco Offline OP
Maine
Looking at putting a set of 18" Ridler 695's on my '78 Sweptline Club Cab, and looking for input on what size I can go to?
I saw a D150 Stepside that had 18x9.5" rears with a 6mm offset, but I heard that the step sides have more room in back.
That truck also had 18x8" on front with 0 offset, which I assume will also be fine on mine.
Any help would be great!!
Re: Sweptline 18" Wheels?? [Re: 1965Monaco] #1627215
06/02/14 04:46 PM
06/02/14 04:46 PM
dogdays Offline
dogdays  Offline
Here's what I used on my '64:
32-11.50 x 15 on 8" rims on the back
31-10.50 x 15 on 7" rims on the front.
I know these aren't 18" rims, but it's the outside edges of the tire/rim combination that matters.
The wheels were American white spokes, you can check back spacing on them. I don't remember, except that they had minimal offset.
The rear tires have a little over 1/2" clearance on both sides. The fronts have a problem with the tire running into the pitman arm drag link when I turn to the left too sharp. I think I'd make the fronts a little narrower and use a little less backspacing if I were to do it again.
The "rubber rake" from the different tire sizes gave the truck a sporty appearance. Well, as sporty as a longbed gets, any way.
I didn't know that post '71s were also called Sweptline. Usually that refers to the '61 - '71 trucks. Or does it?
I just watched the '78 video, seems they were still called Sweptlines in '78.
R.
Re: Sweptline 18" Wheels?? [Re: dogdays] #1627216
06/02/14 11:00 PM
06/02/14 11:00 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have 17"s on mine
Re: Sweptline 18" Wheels?? [Re: bigdad] #1627217
06/07/14 03:16 PM
06/07/14 03:16 PM
Maine
Maine
Great, thank you for your help!
