thick sb valve cover gaskets #1627010
05/31/14 12:22 PM
05/31/14 12:22 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone know where to find thick valve cover gaskets for small block LA. need to be 1/4-3/8" thick.
Re: thick sb valve cover gaskets [Re: mopar dave] #1627011
05/31/14 12:38 PM
05/31/14 12:38 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: thick sb valve cover gaskets [Re: mopar dave] #1627012
05/31/14 12:42 PM
05/31/14 12:42 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
These are actually a little over .200" thick.
It's the thickest I offer, really don't believe there is anything on the market that your looking for.
http://chucker54.stores.yahoo.net/suvaco.html
Re: thick sb valve cover gaskets [Re: roadhazard] #1627013
05/31/14 12:44 PM
05/31/14 12:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why do you one that thick?
Re: thick sb valve cover gaskets [Re: pittsburghracer] #1627014
05/31/14 12:48 PM
05/31/14 12:48 PM
PA.
"Little"John
"Little"John
PA.
http://www.superformanceproducts.com/
Pretty sure the one set I got were at least 1/4 inch thick when I placed my order but I don't see them listed. My be worth a call or PM. I needed a thick set for my fab cover to get them over the manifold.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: thick sb valve cover gaskets [Re: Quicktree] #1627015
05/31/14 12:54 PM
05/31/14 12:54 PM
Mt Morris Michigan
Mt Morris Michigan
been doubleing them up so rockers clear covers, looks like crap. need one thick gasket to clean it up. moroso makes them for small chevy.
Re: thick sb valve cover gaskets [Re: mopar dave] #1627016
05/31/14 12:56 PM
05/31/14 12:56 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Here is what I used to run. .313" thick...
http://www.summitracing.com/parts/fel-1646/overview/make/dodge
Re: thick sb valve cover gaskets [Re: Forest] #1627017
05/31/14 01:01 PM
05/31/14 01:01 PM
Mt Morris Michigan
Mt Morris Michigan
thanks. those should work fine.
Re: thick sb valve cover gaskets [Re: mopar dave] #1627018
05/31/14 01:19 PM
05/31/14 01:19 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
In the FelPro performance line they have thick SB valve cover gaskets. I don't remember the P/N, I actually looked it up on RockAuto.com, got the P/N and ordered from O'Reilly. They were at the store the next day. I have not run it yet, but they fit much better than the OEM gaskets on my '87. Order from Rockauto if you have time to wait and use the P/N resource if you don't.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
