Re: A body Rack and Pinion
[Re: 340duster340]
#1626990
08/26/14 01:16 PM
08/26/14 01:16 PM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
just a thought, can you run c-channel in the front part of the k frame, mount the rack there, and flip the ball joints side to side so the tie rod mounts are facing forward? might have an issue getting the steering shaft all the way up there, but it might work.
Maybe, but it depends. If you just flip them around to put the tie rod mount forward, no, because this introduces anti-ackerman.
If you flip them around and swap sides, maybe, but... the mounting face on the lower balljoint is offset from the axis. So, this move may restore some ackerman, but will narrow track width and possibly introduce caster/camber shortcomings, if you can even mount it to the spindle pads. The ball socket may be a bit too big to mount the joint flat against the spindle. Some minor machine work may be able to offset this, but again, more modifications to the process.
[Re: TC@HP2]
#1626991
08/26/14 06:07 PM
08/26/14 06:07 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
All good points but I don't think reworking it is an option. It will work fine for someone with a Small Block. It would be a shame to cut it up. ![](/ubbthreads/images/graemlins/sawzall-smiley.gif) Its a very nice piece. ![](/ubbthreads/images/graemlins/Twocents.gif)
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
