battery voltage #1626677
05/30/14 12:29 AM
05/30/14 12:29 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..what would be a normal battery voltage while running or what
would you consider too hi?
Re: battery voltage [Re: can.al] #1626678
05/30/14 12:34 AM
05/30/14 12:34 AM
Kirkland, Washington
Pacnorthcuda Offline
While running....13.25 to 14.50
Over 14.50 would get my attention.
Re: battery voltage [Re: can.al] #1626679
05/30/14 12:34 AM
05/30/14 12:34 AM
South
Squirrel_Cat Offline
South
static, 12.3-12.6. Car sitting, you just put a meter on it.
Shouldn't drop below ~10v while cranking, record feature on a multimeter is good for that.
13.5v-14.0v is normal running voltage with a little rpm [mopar alts are lazy at low rpm]. a
Anything about 14.5v would be a little too much IMO.
1973 340 'Cuda 2013 Mustang GT
Re: battery voltage [Re: Pacnorthcuda] #1626680
05/30/14 11:44 AM
05/30/14 11:44 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
That's about what i thought.
Looked like my gauge was just on the "charge" side coming home last night so i checked it at idle..it was about 14.2.
I boiled a battery over a few years ago and am a little paranoid about overcharging.
Think i'll clean and check my connections
..thanks guys.
Re: battery voltage [Re: can.al] #1626681
05/30/14 02:42 PM
05/30/14 02:42 PM
dogdays Offline
dogdays  Offline
14.2VDC = don't worry about it. Modern batteries tend to require a little more voltage to charge.
R.
Re: battery voltage [Re: can.al] #1626682
05/30/14 02:58 PM
05/30/14 02:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
..thanks guys.
You should check at 2500 or so RPM as well.
