Re: Is there more then one type of timing pointer for an RB
[Re: cougar_cat_25]
#1626577
05/29/14 09:36 PM
05/29/14 09:36 PM
RapidRobert
I'm rusty on BB's but ain't the timing tab on pass cars at ~10:30 (pass side). Is that where it is at on this eng? I would assume that even if there was different t covers/dampeners that you have the correct ones in your pile for this eng. You might check exact TDC with the ten dollar tool but slipped dampeners are rare but we gotta start somewhere & k.i.s.s. is always a good plan. What's the idle speed? What springs? what was the highest vac and what was the initial before you backed it off 1 in hg of vac?. Whats the total? Keep us posted! I love the toughies
[Re: cougar_cat_25]
#1626579
05/30/14 12:35 AM
05/30/14 12:35 AM
Posts: 43,225 Bend,OR USA
Cab_Burge
I put together a 78 smog 440 out of a winnebago. Assembly went well and I double checked cam timing marks. I set the initial timing with a vacuum gauge. The idle timing at best vacuum minus 1 is off the pointer, if I had to guess 40 or more degrees. Runs great and drives great, what am I missing?
If you didn't verify TDC on your balancer compared to the timing tab your really lost as far as accuracy, aren't you The outer ring on the balancers can, and will, slip and spin You can pull a spark plug(#1 or #6 ) and put in a screw driver or a positive piston stop, and slowly, and gently, turn the motor over until you feel the piston touch the screw driver end, keep rotating the crank, by hand, until the piston reaches TDC and then compare your balancer to the timing tab If you use a piston stop follow the directions for it to locate TDC BTW, there are multiple different timing covers and balancers for the BB Mopars, depending on which year and body style, car, pick up, motor home, industrial or marine Mopar put a small hole in the class A motorhome tranny bell housings and a mark on the torque converter to check the initial ignition timing with the engine cover off on them
[Re: cougar_cat_25]
#1626581
05/30/14 05:56 PM
05/30/14 05:56 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Initial timing is set with the vacuum disconnected and plugged. Check the shop manual for correct idle speed to check it at. Motorhome engines use a hole in the bellhousing to check timing. Cast crank engines typically have timing marks on the passenger side of the engine and forged on the drivers side.
