Stepside bed interchange ????? #1626137
05/28/14 07:07 PM
05/28/14 07:07 PM
East Texas
Mopar2DBone Offline OP
East Texas
Looking for a SWB stepside be for my 81 W150. What year models can I use? I know the beds are real similar going way back into the 50's maybe? Just wondering how much fab work will be needed for what years?? Thanks..
Re: Stepside bed interchange ????? [Re: Mopar2DBone] #1626138
05/28/14 07:24 PM
05/28/14 07:24 PM
scratchnfotraction Offline
I know my 85 stepside is the last yr for them. it has the metal bed floor. that change came late 70s early 80s IIRC.
Re: Stepside bed interchange ????? [Re: scratchnfotraction] #1626139
05/28/14 07:42 PM
05/28/14 07:42 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
to bolt on a go it has to be a 81-85 stepside bed which has the metal floor, because we tried mounting a 85 s/side bed to a 79 frame and the mounts didn't lineup up front, had to make a offset bracket.
Re: Stepside bed interchange ????? [Re: 98RAM1500] #1626140
05/28/14 08:02 PM
05/28/14 08:02 PM
East Texas
East Texas
Wonder if I could make this work? And would it look ok or be as ugly as homemade soap???
Re: Stepside bed interchange ????? [Re: 98RAM1500] #1626141
05/28/14 08:02 PM
05/28/14 08:02 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Other than the offset brackets the beds are the same from 62 or so
on the early ones you have to cut the filler neck hole
Re: Stepside bed interchange ????? [Re: BulletBob] #1626142
05/28/14 11:29 PM
05/28/14 11:29 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The one pictured is a 51 or 52, those had the old round rear fenders. As long as you use those old fenders (last used in the 52 model year) it will work OK. Should you want to change over to the newer fenders (53-85) and use your old bed sides, you will have fender mounting bolt holes to fill and new fender mounting bolt holes to drill. Somewhere around the 56 model year, the top of bed rails changed from a 45 degree angle to a flat 90 degree angle.
Also, Beds with the wood floors have a different method of mounting the bed sides then the beds with steel floors. I also wouldn't be surprised to find the crossmembers are different. The wood floored beds have the crossmembers mounted to the frame, the wood sits on top of the crossmembers, and the bed sides and metal strips are attached with bolts to the crossmembers above the wood. The wood started life out as 1" thick. The steel floored trucks have to make up the difference in the thickness of the flooring material someplace. Gene
Re: Stepside bed interchange ????? [Re: poorboy] #1626143
05/29/14 12:30 AM
05/29/14 12:30 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
if you looked at a stock stepside truck they used a stock offset bracket----when you pull a bed like that you need to grab the bracket.....bob
Re: Stepside bed interchange ????? [Re: Mopar2DBone] #1626144
05/29/14 12:41 AM
05/29/14 12:41 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
That's the look I want to do with my black shorty
I like those round fenders & have been toying with the idea of having the sides broke & putting a generic fender on it & attaching it all to a narrowed SWB Sweptline bed floor
Re: Stepside bed interchange ????? [Re: BulletBob] #1626145
05/29/14 03:45 AM
05/29/14 03:45 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
53-85 were almost the same. The early the rail sloped than I believe in the early 60s they became flat and other than mounting didne change. Its not hard to make the simple L bracket needed to mount a 70s bed if they are different. I have a 80 and 81-85 bed. Ill have to compare. I need the rear mount for the 80 bed. Didnt have the proper tools to cut the bolts
Re: Stepside bed interchange ????? [Re: 76dodgeboy] #1626146
05/29/14 10:18 AM
05/29/14 10:18 AM
East Texas
East Texas
Well , I found a bed like pictured above about three miles from my house and its just sitting on the back of a same era International truck. I think the guy will let me take it to my house and set it on the frame rails of my 81 to see how it looks before I buy it.. I will take some pics and share when/if I do.. Thanks for the input...
Re: Stepside bed interchange ????? [Re: Mopar2DBone] #1626147
05/30/14 03:38 AM
05/30/14 03:38 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
NO Cross breeding!
