Brake adjustment hole plug #1625441
05/26/14 09:43 PM
05/26/14 09:43 PM
Chicago
curbman68 Offline OP
Chicago
Does anyone know if the hole plug for the brake adjustment hole in the backing plates that are available from the dealer (2072614) still look the same as the originals? I'm trying to not use the solid bodied replacement ones that are available everywhere.
Re: Brake adjustment hole plug [Re: curbman68] #1625442
05/26/14 10:36 PM
05/26/14 10:36 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yes
Re: Brake adjustment hole plug [Re: gtx6970] #1625443
05/27/14 08:29 PM
05/27/14 08:29 PM
Chicago
Chicago
Excellent, thank you!
