leaking pinion seal #1625136
05/26/14 10:16 AM
05/26/14 10:16 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
any tips on changing the front seal on a 489 centre section?
index and change or re torque to 180lbs.
Re: leaking pinion seal [Re: can.al] #1625137
05/26/14 10:40 AM
05/26/14 10:40 AM
Rochester, NY
dusterdood Offline
dusterdood  Offline
Rochester, NY
I watched a youtube video where they pointed out that if you're worried about the pinion bearing preload, you can count the number of threads exposed and mark the nut and tip of the pinion gear (making sure you don't wreck the threads). Make sure you index the yoke the same way. Torque it to about 100 LBS to start, then walk it in slowly until the same mark line up.
mike
