I spoke with Goody and several of my car friends about this issue. Some said that certain differentials need up to 600 lb/ft to start the crush on the sleeve. Goody said he bananna'd a 3/4" breaker on a Jeep's crush sleeve.
Those conversations (along with a heavy load of frustration) made me want to try it again.
My vise is bolted to a metal table. The table itself has been reinforced with 2x6 lumber to distribute heavy loads on the vise. The lower shelf is loaded with cylinder heads and other cast iron pieces. The surface of the table is also loaded with several hundred pounds of stuff that was hidden from view by some cardboard when I made the video. As you can see in that video the table was still moving quite a bit. To eliminate the problem I grabbed my floor jack and used it to ram a piece of bar stock into the table under the vise.
Once the table was secure I picked up the 4' black pipe cheater bar and went all caveman on the pinion nut.
It started to move, slowly at first but it got easier.
NOPE!
I stripped the threads off the old pinion nut.
![](/ubbthreads/images/graemlins/blush.gif)
I pulled it off, cleaned up the mess, and grabbed the new pinion nut. I wasn't going to let this stupid thing get the best of me!
New nut spun on, vise supported, cheater in place, and 230 lbs of gorilla hanging off the bar. It budged a wee bit then...
*POW*I managed to twist the yoke out of the vise.
![](/ubbthreads/images/graemlins/flame.gif)
That thing was really starting to piss me off.
Reset AGAIN. I made sure the yoke was set deeply in the vise and TIGHT. I picked up my ratchet, looked at it, and decided it had just become a sacrifice to the lifetime warranty gods.
This time, before I pulled, I cleared the floor behind me. Something was going to give and when it did, I wanted a relatively safe place for my body to land. If this thing killed me, and it was likely to do so, I wanted my mother to be able to arrange an open casket service.
The socket was put in place with the A in USA on top. I put the ratchet handle about 20 degrees past vertical, and slid the cheater pipe in place. To give the ratchet a fair chance to survive, I began a slow pull on the pipe. As I applied more torque the ratchet began to flex. The long hard pull was severe enough that my arms began to spasm from muscle fatigue. When I finally relaxed, I checked the socket. The A in USA had rolled from the 12 o'clock position around to 1:00 or so.
I checked the play, reset, and did it again.
And again.
And again.
The slop gradually went away. The pinion now turns with about 25 in/b of effort.
The ratchet survived. Kinda. The only reason it's not a boomerang is because I slid the pipe all the way to the head of the ratchet. It was far too much torque to apply on the end of the handle. I did notice that the head is a tiny bit looser than it was before I started this. The low impact pull stretched the head a bit but the guts didn't fail.
Strangely, when the crush sleeve started to deform it did not get much lighter to pull. The effort was still high. My 24" breaker bar wasn't enough and I had to keep the cheater bar in play.
I don't know what Motive Gear made that crush sleeve out of but it is some mighty strong stuff.
I'm beat. My arms are fatigued. Both wrists hurt. Even my legs are a bit tired. I haven't got a clue how much torque I applied to that well lubed nut but rest assured it was a LOT more than what it took to put 440 lb/ft on the centerlock wheel nuts on a Porsche.
