Took carb apart, now I have no pump shot??? #1624813
05/25/14 05:24 PM
05/25/14 05:24 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Ok, low on sleep....not thinking well....I just took my carb apart, swapped jets, and now my front squirters aren't working.....what did I miss? Rear squirters work just fine.
Took it back apart, gasket is not blocking the hole (that I can tell), yes the lever is under the base plate linkage, the umbrella in the accel pump looks ok, float bowl fills with fuel......am I missing something???
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Took carb apart, now I have no pump shot??? [Re: FlyFish] #1624814
05/25/14 07:04 PM
05/25/14 07:04 PM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
Can you blow through the pump nozzle (squirter)?
Can you blow through the main body?
See where I am going with this? I am interested to see what the problem is. Never seen that happen before. From your description I'd guess the problem would be faulty parts or debris.
Re: Took carb apart, now I have no pump shot??? [Re: FlyFish] #1624815
05/25/14 07:52 PM
05/25/14 07:52 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
i am not much of a carb person. but you didn't leave the accelerator needle out/ that is if it even makes a difference?
http://images.search.yahoo.com/images/vi...&hspart=iry
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Took carb apart, now I have no pump shot??? [Re: mopar65] #1624816
05/25/14 09:33 PM
05/25/14 09:33 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Either the needle out or the needle stuck.If you did not leave out the needle and it is not stuck,blow through it with your air hose,if no air hose spray carb. cleaner through it and make sure it is not stopped up.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Took carb apart, now I have no pump shot??? [Re: MRMOPAR622] #1624817
05/25/14 11:01 PM
05/25/14 11:01 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Did you put the pump arm propery on the diaphragm?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Took carb apart, now I have no pump shot??? [Re: hemi-itis] #1624818
05/26/14 12:37 AM
05/26/14 12:37 AM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Ok, well I took a nap, drank some coffee, took the whole thing back apart and blew out all the passages with compressed air...I reassembled the carb and it's working fine now. I have no idea what happened, but it's working now.
Thanks everyone
Re: Took carb apart, now I have no pump shot??? [Re: FlyFish] #1624819
05/26/14 12:38 AM
05/26/14 12:38 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Bowl gasket on backwards? Seen some that have only one pump hole in them.
Re: Took carb apart, now I have no pump shot??? [Re: RobX4406] #1624820
05/26/14 03:51 PM
05/26/14 03:51 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
You had the gasket on backwards.
One day I will have something cool here.
