Re: Harland Sharp - T&D Rockers
[Re: Gabby63]
#1624539
05/25/14 12:12 AM
05/25/14 12:12 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought my T&D rockers from Nick at Compuflo for my 440-1 heads and I've bought a couple set of Harlan Sharp rockers from Todd at CompititionWedge. http://www.compu-flow.com/T&D%20Rockers.htm
[Re: pittsburghracer]
#1624540
05/25/14 12:36 AM
05/25/14 12:36 AM
Todd at Marsh Performance / Moparts Connection or Comp Wedge--killer Harland deals --T&D is a PIA getting parts from --Harlands are Always on the shelf---Always go Jesel VS> T&D and you will be way better off--That being said Harlands are the best all around easy to use and PLENTY strong enough. Just take some care setting up side clearence per pair--the spacer washers they send with any rockers are not always a good match to the hold downs you may be using--just mix / match spacers and shims to get enough room per pair--check with everything tight --you can loosen and slightly move each seperate hold down sometimes--just keep at it until all 8 pairs are just right I Love Harland Sharps and now Todd has them w/o the needles for a little less
[Re: Gabby63]
#1624541
05/25/14 01:58 AM
05/25/14 01:58 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Harland sharp vs T&D is like comparing Justin Bieber to Floyd Maywether..Bieb's being the harland.
[Re: ]
#1624542
05/25/14 02:08 AM
05/25/14 02:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've never had any issue buying sets or parts from T&D... and T&D is far better than HS ![](/ubbthreads/images/graemlins/wave.gif)
[Re: bwhackd34]
#1624544
05/25/14 09:41 AM
05/25/14 09:41 AM
T&D and Jesel --Same League way better than Harlands but Jesel way better to deal with -always in stock--NO waiting T&D ..you may wait until Christmas Harlands are almost indestructable and are user friendly and almost 1/3 less than the others I was not saying they are the same as Jesel/T&D but as a dealer I order Jesels--I get rockers in a few days--as a dealer I order T&D and who knows when or what year they may arrive I think Harlands are the best way to go on Indys that he already has since his heads are not cut for shaft rockers --he can pop them on what he has now. The Dove rockers Indy has sold for years are good flat tappet rockers but are no way strong enough for modern roller spring pressure--Indy knows it, has always known it and hundreds of Indy customers have had failures but..Indys bank account has had zero failures from rockers. 90% of Mopar racers can go with Harlands and have zero problems--I love them--I just hate places that are always on back order building to order and putting you Way behind on projects--T&D makes that a specialty--Jesel makes and SHIPS rockers on demand and so does Harland--thats all
[Re: ]
#1624545
05/25/14 11:05 AM
05/25/14 11:05 AM
MR_P_BODY
I've never had to wait for my rockers from T&D.. I would get them within a week... I think I've had about 12 sets of T&D... mainly small block but 1 set for my B-1 stuff... I have or had both styles of their rockers with the common shaft and the short shafts... this is the set on my W-9 with the short shafts ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1624548
05/25/14 12:10 PM
05/25/14 12:10 PM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
I don't have any experience with T and D or Jesel rockers, but I bought my Harland Sharpe's from Todd at Competition Wedge and recieved excellent service, so I wanted to recommend him for that.
Better get inside Ma. Looks like a storm's comin'.
[Re: Gabby63]
#1624550
05/25/14 12:38 PM
05/25/14 12:38 PM
MR_P_BODY
Ok all , I was looking for info and got it . Thank you . I did not want to lean one way or the other and keep a hopeful eye on what was said but not have to read between the lines . I appreciate all your replies I really do . Does any one have contact info for either one ? Are they to be contacted through Moparts ? PM ? I want to get this back together ASAP like everyone else . I hate having issues this early in the season . Are there any other things I need to watch out for while setting them up ? I heard that with the needle brgs. with the Harland Sharps you need to orfice the oil lines because you loose so much pressure up top which can cause issues with the bottom end . Can anyone address this ? Thanks Gary
The common shaft T&D uses the standard through the head oiling.. the small shaft type uses push rod oiling.. just the normal check with any rocker , check the side clearance and the sweep on the valve tip to see if they need any change... with the heads you have I'm sure you would want the common shaft so you dont have to mill off the stands ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Gabby63]
#1624552
05/26/14 02:11 AM
05/26/14 02:11 AM
Dartthunder340
Gary, I thought I had Todd's info saved and now I cannot find it. I will keep looking. I remeber Todd Tuohey (?) Competition Wedge Engines and I believe it's in New York.
