Trans was working good before...removed the front pump to drill case and relocate vent from stock location. Drilled and tapped the case and installed a fitting for the vent. Removed the stock plastic vent and installed a pipe plug.
I did not snug the front band adjustment before removing pump to hold anything. On reassembly the pump needed to be tapped and bolts snugged more and tapped to get the pump in. After doing this the shaft does not have any endplay and does not want to turn by hand either. Heard a possible pop sound while torquing the bolts..may have been the pump seating itself?
I am guessing something came out of alignment while the pump was out and the transmission was horizontal? Trans was sitting horizontal with pump removed for a few days. Trans was also drained for several weeks before the pump was removed and installed again.
Any idea what is going on in the trans and how to fix or investigate further?
Thanks for any advice.
