Flow numbers for Edelbrock Hemi heads #1624026
05/23/14 12:29 PM
05/23/14 12:29 PM
North Carolina
sasquatch Offline OP
North Carolina
Int 100-86 200-168 300-238 400-313 500-375 600-398 They actually stall above that .
Exh 100-70 200-140 300-188 400-223 500-242 600-249
These were tested OOTB with zero prep of any kind on a historically conservative bench. Tune up the valve job a little and smooth out s few wrinkles and 425 to 430 and 290 to 300 look to be pretty easily achieved without heroic measures.
Just thought y'all might like to know....Todd
Re: Flow numbers for Edelbrock Hemi heads [Re: sasquatch] #1624027
05/23/14 12:34 PM
05/23/14 12:34 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
dont know much about Hemis but that is some real nice numbers! do they work with stocktype parts? (rockers/intakes/headers/valvecovers and such)
Re: Flow numbers for Edelbrock Hemi heads [Re: sasquatch] #1624028
05/23/14 01:01 PM
05/23/14 01:01 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Todd; Did YOU tested them or are those Edelbrock numbers?
Re: Flow numbers for Edelbrock Hemi heads [Re: Rob C] #1624029
05/23/14 01:08 PM
05/23/14 01:08 PM
North Carolina
North Carolina
They were tested here in North Carolina. Yes they use all stock type parts Except the intake valve which is 2.32.I have not seen any numbers from Edelbrock except HP numbers from dyno tests.
Todd
Re: Flow numbers for Edelbrock Hemi heads [Re: sasquatch] #1624030
05/23/14 01:13 PM
05/23/14 01:13 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Thanks Todd! Now where do I find a new HEMI block to start this pipe dream????
LMAO!
Re: Flow numbers for Edelbrock Hemi heads [Re: Rob C] #1624031
05/23/14 01:34 PM
05/23/14 01:34 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
LMAO!
Keith Black
2011 Drag Pak Challenger
Re: Flow numbers for Edelbrock Hemi heads [Re: rickseeman] #1624032
05/23/14 01:43 PM
05/23/14 01:43 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Re: Flow numbers for Edelbrock Hemi heads [Re: rickseeman] #1624033
05/23/14 01:46 PM
05/23/14 01:46 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
If I read the Edelbrock ads correctly the exh valve angle has been moved.It would follow the exh valve notch in the piston will need recutting to match.They do claim they are bolt on using the stock valve gear,covers,etc.
Leave the gun.......take the Cannoli's....Mike
