manual steering conversion #1623300
05/21/14 10:33 PM
05/21/14 10:33 PM
michigan
6pakdakota Offline OP
michigan
I have an 88 d100 with power steering. Will an 88 manual steering box just bolt up, or are there other components that will need to be changed as well?
Thanks.
Re: manual steering conversion [Re: 6pakdakota] #1623301
05/21/14 11:39 PM
05/21/14 11:39 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
other components needed
I am truckless..
Re: manual steering conversion [Re: 340SHORTY] #1623302
05/22/14 12:44 AM
05/22/14 12:44 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The intermediate steering shaft is longer for a manual box the shaft between the box & column
BTW I think 87 was the last year for manual steering
Re: manual steering conversion [Re: BulletBob] #1623303
05/22/14 01:02 PM
05/22/14 01:02 PM
michigan
michigan
That isnt to bad. Now I just need to find a donor truck.
Re: manual steering conversion [Re: 6pakdakota] #1623304
05/22/14 01:51 PM
05/22/14 01:51 PM
Clinton Twp. Michigan
coronet1966d Offline
get a borgeson steering shaft, the impossible part to find is the pitman arm, don't buy a box unless it has one on it because you cant find one
Re: manual steering conversion [Re: 6pakdakota] #1623305
05/22/14 01:54 PM
05/22/14 01:54 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i see several manual steering boxes, with steering shafts for sale using google. i looked at '86 models, to find them. seems to be around 200 bucks for them, some with free shipping even.
Re: manual steering conversion [Re: Golden-Arm] #1623306
05/22/14 04:41 PM
05/22/14 04:41 PM
I did the manual steering swap on mine.
Borgenson steering shaft is telescopic and eliminates that crappy box joint on the factory shaft and not to mention tightens everything up feel wise
I bought a remanned manual box and of course didn't come with the pitman arm, got lucky and found an NOS one after a month of searching
If you don't have one already its a great time to add the steering box frame brace while you are in there
Enjoy the arm workout, its fun with a 440 up front
Re: manual steering conversion [Re: coronet1966d] #1623307
05/22/14 06:09 PM
05/22/14 06:09 PM
scratchnfotraction Offline
I have the manaul box from a 85 d100 on my 88-440 truck with the frame/box brace/stock swaybar up front.
corners like it is on rails but does take a good amount of driver input to fly it.
manual steer + manual brakes + manaul shift + dirt roads = thumbs outside the steering wheel at all times doing lots of
Re: manual steering conversion [Re: coronet1966d] #1623308
05/22/14 08:18 PM
05/22/14 08:18 PM
michigan
michigan
Mine also has a 440. It should be a hand full.
